rascalrv
Topic: 2015 R-Pod 179 Posted: 13 May 2014 at 2:02pm |
I tow my 179 with a Ford Explorer 4wd with factory towing package that tows up to 5,000 pounds and I can feel the truck strain a bit going up bigger hills, etc. Level roads it cruises along just fine.
As a side note, since your from Wisconsin you might consider joining about 25 other Rpod Units along with other Forest River products at the 3rd annual Forest River Frog Camping Rally in Goshen, Indiana this August. Details below
R-PodKids
Posted: 13 May 2014 at 12:06pm |
Is anyone pulling with a Lexus RX-350? Interested to know how it's working and what you all added to your purchase to be able to pull the R-Pod comfortably.
R-PodKids
Posted: 13 May 2014 at 12:02pm |
We ordered from Couchs RV Nation out of Indiana so it's getting shipped to us. They are giving us all the bells and whistles and a great price, BUT if we would have told Camping World what we were getting, they would have matched it.
CasaJack
Posted: 13 May 2014 at 10:01am |
I have the WD with stabilizer and I am glad I do especially when we ran into very high winds in Palm Desert, CA about a month ago. I recommend it. I also agree that you probably don't need the extended mirrors.
Jackdaddy
Posted: 13 May 2014 at 9:30am |
Welcome to both of you. I agree that the mirrors are usually unnecessary since the pod is fairly narrow. The brake controller is mandatory - you might look into the Tekonsha RF since it doesn't involve any work on the TV other than plugging into the power outlet, and almost no work on the camper, to install it. Some here feel fine w/o sway control, I used to tow a popup that was suicide to tow w/o so I was happy to tow the pod for a while w/o. Less hassle. Then I had a bad day with wind and decided to get it, and went ahead with a weight distribution hitch that also has sway control. I have the E2 600/6000 model.
outermostpod
Posted: 13 May 2014 at 8:36am |
We use a fastway E2 weight distributing hitch with sway control. Our TV is a 2014 Hyundai Santa Fe rated to tow 5000 lbs. The E2 was $250, is easy to install and easy to connect each time. We weren't sure if we would need it, but decided for $250 it was worthwhile for peace of mind. It does not have to be disconnected for backing up, and you don't have to drive/tow any differently than you would without it. Tongue weight is still obviously important, but the E2 makes it easier to achieve the proper stance. I don't have any experience towing without the E2 but I can tell you that we have had no problems with sway. Probably too late, since you ordered them, but we don't find mirror extenders to be necessary. The rpod is narrower than most trailers, and we have no problem seeing around it.
NormanHill
Posted: 12 May 2014 at 11:38pm |
I.m also anew owner and struggling with the WD hitch with or without a stabilizer. I've only towed it about ten miles from Camping World to my house in Madison and was surprised by how poorly It towed. Sway and bounce, but this was empty. My TV is a 1998 F150 4x4 w/4.6 v8. I.m pretty sure I didn't have enough tongue weight.
Some questions:
Does anyone have a floor plan that shows the location of water tanks with relationship to the axle? With this light a trailer, thinking it would have less than 400 lbs tongue wt, will a WD hitch do me any good? If so, any recommendations. I'm used to dual axles so maybe sway control without the WD hitch would make sense, reasonable?
We're taking off on a longer trip next week somI want to get this figured out soon.
Thanks to anyone with advice!
rascalrv
Posted: 12 May 2014 at 9:19pm |
Where did you purchase your 179? I got mine at camping world in Madison.
R-PodKids
Posted: 12 May 2014 at 6:57pm |
Thank you! I think my husband and I thought as long as our vehicle had the capability to pull the weight of the R-Pod, we could just hook up and go! But we're finding there are several things we need to do first and it's getting a little mind-boggling.
We are planning to pull the 179 with an RX-350 which has a limit of 3,500 lbs. We are scheduled to get a brake system installed in my vehicle, I guess so when we brake with our vehicle, the R-Pod will brake as well. We've heard yes's and no's to the stabilizer bar. I'd love your comments on that. And I guess there's the kind you can leave on when you park the R-Pod and the kind you have to take off or you'll jackknife. And now my husband is ordering mirror extenders for my vehicle. (I guess I should use the term TV, right?  )
Looks like most people end up getting a different mattress. Ideas for which one turns out to be the best? I see they can get pretty pricey, too. Short-queen sheets probably needed too.
Anything else you can think of before we tow this thing away, please pass the info on.
Much appreciated!
Leo B
Posted: 12 May 2014 at 6:06pm |
Welcome to the group!!
