  New Posts New Posts RSS Feed: Battery Disconnect
Topic ClosedBattery Disconnect
cody91 View Drop Down
Direct Link To This Post Topic: Battery Disconnect
    Posted: 05 May 2014 at 9:28am
I'm planning to mount a battery disconnect switch directly to my battery box.  Does it matter if I configure the switch to disconnect the positive or negative cable?  Also, does it matter what gauge cable I run from the switch to the battery?  It looks like the main battery cables are 6 gauge.
Thanks.
Direct Link To This Post Posted: 05 May 2014 at 12:04pm
Put the disconnect on the positive side.  Go as large as you can with the wiring, but don't worry if you can't use the same size as the existing wiring.  The new wiring has a very short run and you aren't running a high- amperage appliance like a starter so there won't be much of a voltage drop with smaller wiring.  I used a pre-wired weatherproof fuse that had 12 gauge wire, but I don't worry about it since the new wire is only a few inches long.
Direct Link To This Post Posted: 05 May 2014 at 1:51pm
Thanks.  I was having trouble finding 6 gauge wire.
Cody91
outermostpod View Drop Down
Direct Link To This Post Posted: 05 May 2014 at 2:00pm
I was able to find the correct wire at West Marine.  They had a short length of 6 gauge with connectors already attached.  Probably most marine places would have it though.  You can order any length any gauge you want from Westmarine.com
Connected to a marine-grade battery cutoff switch to the positive side.
Outbound View Drop Down
Direct Link To This Post Posted: 05 May 2014 at 5:17pm
Just use a couple of starter cables - they're perfect for the job and available most everywhere automotive parts are sold.
Direct Link To This Post Posted: 05 May 2014 at 9:47pm
Very cheap at Walmart, I used about 18 of them to connect a bunch of deep cycle batteries I had for years.
Seanl View Drop Down
Direct Link To This Post Posted: 06 May 2014 at 7:48am
I was just going to say that I converted my Rig over for Dual battery and I used starter cables to connect them.
Direct Link To This Post Posted: 06 May 2014 at 8:34am
I recently went to dual (6v.) batteries too and found starter cable on sale @ Tractor Supply for $5.99! Bargain.
Yesterday, I bought 40' of 10AWG thin stand for adding a couple more 12v. outlets. Home Depot - $0.39 a foot. Thought that was a pretty good deal too.
Direct Link To This Post Posted: 06 May 2014 at 9:45am
If anyone is coming through MD you are welcome to some of the ones I have.  I dismantled my big battery bank last year (which I used with this system) when it died and now I use a much smaller one.  No need for those cables.
Direct Link To This Post Posted: 06 May 2014 at 9:54am
Wow Doug. That is so cool! What died? The Prius or the UPS? I get "the look" when I just walk around my wife's car - not brave enough to do what you did.
Now I gotto look up the towing capacity of a Tesla!
