Page 12> |
| Author | ||
cody91
Joined: 12 Feb 2014 Online Status: Offline Posts: 184 |
Topic: Battery DisconnectPosted: 05 May 2014 at 9:28am |
I'm planning to mount a battery disconnect switch directly to my battery box. Does it matter if I configure the switch to disconnect the positive or negative cable? Also, does it matter what gauge cable I run from the switch to the battery? It looks like the main battery cables are 6 gauge.
Thanks. |
Joined: 29 Jul 2009 Location: MD Online Status: Offline Posts: 9066 |
Posted: 05 May 2014 at 12:04pm |
Put the disconnect on the positive side. Go as large as you can with the wiring, but don't worry if you can't use the same size as the existing wiring. The new wiring has a very short run and you aren't running a high- amperage appliance like a starter so there won't be much of a voltage drop with smaller wiring. I used a pre-wired weatherproof fuse that had 12 gauge wire, but I don't worry about it since the new wire is only a few inches long. |
cody91
Posted: 05 May 2014 at 1:51pm |
Thanks. I was having trouble finding 6 gauge wire. Cody91 |
outermostpod
Joined: 06 Nov 2013 Online Status: Offline Posts: 43 |
Posted: 05 May 2014 at 2:00pm |
I was able to find the correct wire at West Marine. They had a short length of 6 gauge with connectors already attached. Probably most marine places would have it though. You can order any length any gauge you want from Westmarine.com
Connected to a marine-grade battery cutoff switch to the positive side.
Outbound
Joined: 19 Nov 2009 Location: Oshawa, Ontario Online Status: Offline Posts: 767 |
Posted: 05 May 2014 at 5:17pm |
Just use a couple of starter cables - they're perfect for the job and available most everywhere automotive parts are sold.
Posted: 05 May 2014 at 9:47pm |
Very cheap at Walmart, I used about 18 of them to connect a bunch of deep cycle batteries I had for years.
Seanl
Joined: 19 Sep 2011 Location: Fredericton NB Online Status: Offline Posts: 633 |
Posted: 06 May 2014 at 7:48am |
I was just going to say that I converted my Rig over for Dual battery and I used starter cables to connect them.
fwunder
Posted: 06 May 2014 at 8:34am |
I recently went to dual (6v.) batteries too and found starter cable on sale @ Tractor Supply for $5.99! Bargain.
Yesterday, I bought 40' of 10AWG thin stand for adding a couple more 12v. outlets. Home Depot - $0.39 a foot. Thought that was a pretty good deal too. fred
Posted: 06 May 2014 at 9:45am |
If anyone is coming through MD you are welcome to some of the ones I have. I dismantled my big battery bank last year (which I used with this system) when it died and now I use a much smaller one. No need for those cables. |
fwunder
Posted: 06 May 2014 at 9:54am |
Wow Doug. That is so cool! What died? The Prius or the UPS? I get "the look" when I just walk around my wife's car - not brave enough to do what you did.
Now I gotto look up the towing capacity of a Tesla! fred
Page 12> |
