David and Danette
Topic: New Awning Concept Posted: 10 Apr 2014 at 4:05pm |
It helps to use a pair of pliers to bend the corners of the track to flare them out on the end that you feed the awning into. And some have including myself have replaced the screws to give more clearance in the track when doing this stainless steel screws were used.
2023 Aliner Scout Lite
Leo B
Posted: 10 Apr 2014 at 4:36pm |
We will also spray a little bit of silicone in the track which helps the dome slide through a lot easier.
Previously owner
wingnut2312
Posted: 10 Apr 2014 at 4:41pm |
Thanks guys! We'll try the filing down first. I think Robin would shoot me if she saw something bent out. Lol
2014 rpod 182G
Ford Expedition
marwayne
Posted: 10 Apr 2014 at 7:29pm |
I would definitely flare the ends.
Goose
Posted: 10 Apr 2014 at 8:07pm |
I bought a small 1/8 inch round bit for the Dremel Tool that I have to remove the burrs on the inside of the track were the screws are. You can not get a file on the inside and this worked perfect. Goose
wingnut2312
Posted: 10 Apr 2014 at 9:00pm |
Marwayne- I think I can get away with that!!
Little jump again...can you use bleach water in the hot water tank when de-winterizing the pod?
2014 rpod 182G
Ford Expedition
RPodWeGo
Posted: 11 Apr 2014 at 11:20pm |
Walt,
I'm looking forward to the pics. A open design would be just the thing for us in the southwest as we really don't have bugs and it is ussually dry. More so for shade and that occasional thundercloud.
RPodWeGo
RPod 177
04 v8 Toyota 4Runner
Kermit
Posted: 18 May 2014 at 4:26pm |
Any news on this?
'14 182g
Towed by various Jeeps
rhs
Posted: 25 Jun 2014 at 5:44pm |
I ordered one for my 178. It did not work. After talking to Mike it was determined that the one they made was not suitable for that model (not long enough). Sent mine back on their authorization. As far as I can tell they do not make one for a 178.
Row pod
Posted: 26 Jun 2014 at 5:49pm |
We love the Dome, but thought an awning would be best for one-night trips and to let us take the Dome down to dry before storing. As we all know, the R-pod awning market is nonexistent, so as we do frequently, we made it ourselves. Purchased a clearance 7x12' piece of awning material ($70.00 including shipping). The cord on the awing was not big enough around, so we bought a roll of soft clear plastic tubing and split it long-wise to fit over the awning's cord - glued it there. This fits in the same track as the Dome. Then purchased two replacement fiberglass tent poles with tension cord, cut them to fit into a seam that I sewed onto the other end of the awning. Put in 3 grommets, bought aluminum extension tent poles and made straps to anchor with stakes to the ground at an angle. The total costs for all parts was less than $125.00 and a little sewing time. We will be bringing it to the Oregon Rally in September.
