  New Posts New Posts RSS Feed: GENERATOR
Topic ClosedGENERATOR - Event Date: 27 Feb 2014 - 27 Apr 2014
 Post Reply Post Reply Page  <1 45678 12>
CharlieM View Drop Down
Direct Link To This Post Calendar Event: GENERATOR
    Posted: 03 Mar 2014 at 3:44pm
For what it's worth, the 110/220 and 120/240 designations are essentially identical. Way back in history the official US power definition was 110/220. That was changed to 120/240 within recent, but still ancient, history. Maybe 1950-1960. I was there, but I'm too old to remember exactly. Anyone using 110/220 these days is showing their age Big smile.
hogone View Drop Down
Direct Link To This Post Posted: 03 Mar 2014 at 4:20pm
Thanks Charlie..........I feel much better now!!!!!  I guess then what is confusing is they call the four separate outlets 110 and the 30 amper 120/240, so maybe I had a good excuse (I'm reachin!!) for being confused!
Jon & Pam
2025 GD 17MKE
2013 RP177(sold Nov 25)
2023 F150
2017 HD Streetglide
CHEESEHEAD
Sleepless View Drop Down
Direct Link To This Post Posted: 03 Mar 2014 at 4:24pm
Charlie, I must be older than dirt.  Back in the Midwest when I was growing up, we referred to everything as either 115 volts or 230 volts.  Smile
Bob
2014 R-Pod 178 (OUR POD)
2009 Chevrolet Avalanche
Direct Link To This Post Posted: 03 Mar 2014 at 4:33pm
You guys know better than I, but based on the pics I posted above, and with the right pigtail (110 to 30 AMP), can I use my Yamaha 2400 iSHC to feed the transfer switch panel? Knowing, of course, I can't use the well pump which is on a 220 (double breaker) circuit.
I'd like to be able to run the little guy when I only need a circuit or two.
Does that make sense?
Thanks.
Direct Link To This Post Posted: 03 Mar 2014 at 5:17pm
OK. From the top.
Jon: The 110/120 disconnect is because your generator panel is written in Chinglish. They should be the same, either 110, 115, or 120. All the same practically.
Bob: Not older than dirt, just caught up in the inflation cycle. 110 became 115 became 120. Who knows about tomorrow Smile.
Fred: Your 2400 can be wired to the transfer switch to run your house. However, your house is wired to split 120 circuits between the two phases of the 240 volt service. You will have to wire the pigtail such that it connects phase A and B together on the generator side of the transfer switch and connects them to the 120V socket on the 2400. This allows all 120V household devices to be powered, subject to the 2400 wattage limits. This can be done safely; that's what I do with my 3600W Honda. But, if you don't really understand this, I would ask for some local help. A licensed electrician may not do it for you since it probably violates ObamaCare LOL.
Direct Link To This Post Posted: 03 Mar 2014 at 5:51pm
Thanks Charlie! I don't think my electrician will have any problem with that.
When I asked him to do the outside port and transfer switch, he said. "Why? Just plug it into the dryer outlet like everybody else does around here!"
I was just scared I might fry one of the linemen fixing the problem...
Direct Link To This Post Posted: 03 Mar 2014 at 6:00pm
Let me confuse the subject a little more, as I remember from my younger years in Germany regular power is 220 or 240 volts the high voltage is 340 or 360 volts
Keith-N-Dar View Drop Down
Direct Link To This Post Posted: 03 Mar 2014 at 6:17pm
The reason not to plug it into your dryer plug is that you could have live male terminals on your cord from the genny.  I recommend a real plug and a working transfer switch.  Also have a driven ground rod near where you want to set the generator and ground the frame before using.  If you don't have a transfer switch you could fry a lineman trying to get your power back, and if you have live power on the male connector you could fry yourself or a family member.  This is not safe.  And if my electrician suggested I do what yours did I would get a different one.
2011 R-Pod 177
2010 Ford F-150
Direct Link To This Post Posted: 03 Mar 2014 at 6:34pm
Keith, question? how can I fry a lineman if my main breaker is tripped, there is no power going from my breaker panel to the power pole.
Direct Link To This Post Posted: 03 Mar 2014 at 7:18pm
I am old school when it comes to connecting a generator to a household distribution system.  My experience is limited to connecting only 5 or 6 when we lived in the Midwest.  I would always install a 7500 watt transfer switch, properly recessed into the interior wall of the home.  This normally handled either 6 or 8 circuits, and incorporated ammeters in each leg of the box.  On the outside wall of the home, I would install a generator inlet box, which was required by our local codes.  Code also required a ground stake in place by the inlet box.  All of my components were Generac, purchased from either Lowes or Home Depot.  I don't know of a safer way to connect a generator's output to a household electrical panel.
Again, I am old school.  My last installation was 12 years ago.
