  New Posts New Posts RSS Feed: GENERATOR
Topic ClosedGENERATOR - Event Date: 27 Feb 2014 - 27 Apr 2014
 Post Reply Post Reply Page  <1 56789 12>
CharlieM View Drop Down
Direct Link To This Post Calendar Event: GENERATOR
    Posted: 03 Mar 2014 at 3:44pm
For what it's worth, the 110/220 and 120/240 designations are essentially identical. Way back in history the official US power definition was 110/220. That was changed to 120/240 within recent, but still ancient, history. Maybe 1950-1960. I was there, but I'm too old to remember exactly. Anyone using 110/220 these days is showing their age Big smile.
Direct Link To This Post Posted: 03 Mar 2014 at 2:22pm
hogone, this might help.
My setup...
Cord: male end to 30 AMP generator  port:
30 AMP Port on outside of house: female end of cord
Transfer switch panel next to and wired to main breaker panel:
My routine is to hook cord up, start generator, go to transfer switch all breakers to generator. Not quite automatic, but not bad...and safe. I've been pretty good at guessing when the power might go out, so I hook the generator up and if the power does go, I simply push the start button on the generator and switch the breakers to generator. I do keep one (light) circuit on mainline power so I know when the power comes back on. I have a neighbor that didn't realize power was back and ran his generator for two days after power had been restored!
Hope that helps.
hogone View Drop Down
Direct Link To This Post Posted: 03 Mar 2014 at 2:03pm
Huron:    Amazon has a camco cord (55382) for 26.03
Jon & Pam
2025 GD 17MKE
2013 RP177(sold Nov 25)
2023 F150
CHEESEHEAD
Direct Link To This Post Posted: 03 Mar 2014 at 1:31pm
I guess what keeps tripping me up is this receptacle on the gen is 240/120; not 220/110...........again I'm pretty green on this electrical stuff.  So if I am understanding all this correctly (again I'm talking about hooking up to the pod); if I purchase this adaptor as mentioned above by Huron and plug the pod cord in; is it just like hooking up to a 30 amp outlet like in a campground?
Jon & Pam
2025 GD 17MKE
2023 F150
CHEESEHEAD
Direct Link To This Post Posted: 03 Mar 2014 at 1:26pm
Yeah I agree it helps a lot if your breakers are marked.
Direct Link To This Post Posted: 03 Mar 2014 at 1:07pm
Originally posted by marwayne
Here is what I am planning to do in my house. Install a dryer vent plug (220 V) outside the house run, a 30 AMP wire to the dryer vent plug in the house. Trip all breakers including the main breaker, your power now comes in the house through your dryer wiring to the breaker panel. Now you can control your power by selecting breakers to be turned on and off.
Since my big genny is 30amp, I just built a cord that plugs into my welder circuit. But other than that, we do it the same. I made up a laminated card with instructions and hung it in the breaker box. (just in case I am not here when it's needed)
Direct Link To This Post Posted: 03 Mar 2014 at 12:54pm
Sleepless View Drop Down
Direct Link To This Post Posted: 03 Mar 2014 at 9:28am
Originally posted by hogone
Thanks for all the info.  One last question for all. So I should get an adaptor for the 120/240 socket for the pod, or use just the standard plug ins?  The 120/240 does come with a cord that splits into 4.    hogone
I normally use the cord that came with the generator.  Each of the 4 terminal cords is 120 volts, and I use that cord to run from the generator to the inside of the house.  From there, I run extension cords to whatever I want to power, usually lights, a small TV, etc.  I keep one free, which I will plug into the refrigerator, microwave or the electronic ignition of our gas range.  I never run the micro or refrigerator at the same time.  That "split" cord eliminates running several separate extension cords from the generator, and it is heavy gauge which eliminates overloading cords at the generator.
2014 R-Pod 178 (OUR POD)
2009 Chevrolet Avalanche
OK, let me know.  I appreciate all the info.
Jon & Pam
2025 GD 17MKE
2023 F150
CHEESEHEAD
HuronSailor View Drop Down
Direct Link To This Post Posted: 03 Mar 2014 at 9:24am
I'm looking for one for myself now. Just found this at Home Depot:
http://www.homedepot.com/p/PowerFit-Outlet-Adapter-30A-240-Volt-To-30A-RV-PF923055/203213234
For under $20 I might try this. I'll ask an electrician buddy of mine first.
