Page <123> |
| Author | ||
Joined: 03 Apr 2011 Location: Mayville, WI Online Status: Offline Posts: 1447 |
Calendar Event: Low point drain 178Posted: 10 Nov 2013 at 6:48pm |
Being neurotic about freezing up the Pod I blow the system out then pump the pink stuff. I want to be sure that no water is standing anywhere to freeze. I know folks that blow out the system and don't use the pink stuff and have no problems, and those who pump the pink stuff through and don't blow out the water first and have no problems.
I have never opened the low point drains other than the one on the water tank. The air and the pink stuff takes care of the low points in the lines for me. |
Joined: 14 Jan 2013 Location: Near Nashville Online Status: Offline Posts: 1456 |
Posted: 10 Nov 2013 at 7:47pm |
Undiluted RV antifreeze is supposed to protect pipes to minus 50. I don't know how well it mixes in the bottom of a still pipe. Probably well enough. But due to their location and purpose, the low point drains are probably the most susceptible to freeze damage of any thing on the pod. If the drains do burst they'd be cheap to fix. Maybe a little trouble, dealing with insulation. How do you flush the antifreeze without opening the low point drains though? TT |
FJ Cruiser |
dsmiths
Joined: 10 Oct 2011 Location: Southern Ind Online Status: Offline Posts: 866 |
Posted: 10 Nov 2013 at 7:49pm |
I am with Keith N Dar, I use a blow out plug to clean the pressure water inlet but then I go under the sink, switch the valve on the water pump and pump the pink r.v. antifreeze through the system. this is after you take out the anode rod on the water heater, replace or retape it and switch the bypass valves on the water heater. It only takes about 30 to 50 minutes to winterize the system and it sure beats making expensive plumbing repairs. sleep tight little pod. spring is around the corner.
Dane and Donna Smith
Jdub
Joined: 17 Mar 2013 Online Status: Offline Posts: 94 |
Posted: 10 Nov 2013 at 7:52pm |
Posted: 10 Nov 2013 at 8:28pm |
When I am done with the air there is no water in the system, so the pink stuff is pure in the lines. In spring I fill up the tank and start the pump, then run the water in each location until they run clear. Pink stuff gone. |
Posted: 10 Nov 2013 at 8:33pm |
FWIW I shared what I do. If anyone wants to use the low point drains then they should. FR puts them on the pods for a purpose, and I don't want to have anyone not do what they feel is the right way to winterize just because of the way I do it. It has worked for me but YMMV.
fwunder
Posted: 10 Nov 2013 at 9:15pm |
I'm going with the Wisconsin folks! That's like close to the arctic circle. They know cold!
I do think, however, the best way to winterize is to go south! fred
Bill-GA
Joined: 13 Jan 2012 Location: Cumming, GA Online Status: Offline Posts: 214 |
Posted: 10 Nov 2013 at 10:46pm |
Aside from the FW tank drain, I have 2 low point drains that point straight down with caps. I ALWAYS opened and drain them. I blow out the lines first, then drain them, then add pink stuff. It usually only gets down to 20 degrees for a week in GA, but I'd be concerned that the small amount of water would freeze and cause damage. Blowing the lines out with air doesn't clear those downward pipes. It takes about 2 minutes to do it ... Better safe than sorry.
I moved south from the NE ... But not south enough!
Bill & Bev
13 yr old dachshund 'Elsa' 2010 RP-176T (tent & slide-out) 2011 Toyota Tundra 2WD TV |
Posted: 10 Nov 2013 at 11:54pm |
You might be surprised if you were to open the low point drains after you blow out the lines and before you put any antifreeze in. Not saying your method doesn't work. Obviously it does. Probably mostly due to diluted antifreeze and the Pex tubing, or whatever it is the pipes are made of, that tolerates at least some freezing without bursting. The drains are like appendixes though; water doesn't circulate in them and you can't blow them out without opening them. For what it's worth, the caps on my drains are only hand-tight. No tools needed to open or close them. TT |
FJ Cruiser |
hogone
Joined: 09 Apr 2013 Location: High Ridge, MO Online Status: Offline Posts: 1070 |
Posted: 11 Nov 2013 at 7:03am |
a couple questions when blowing lines out. do you just turn on all the faucets and pull the toilet handle all at once or one at a time? also i recall last year after i finished pumping af through the system, the last thing i did was open the two low water drains and quite a bit of clear water came out prior to the pink stuff, so there definitely is some left over water down there.
Jon & Pam
2025 GD 17MKE 2013 RP177(sold Nov 25) 2023 F150 2017 HD Streetglide CHEESEHEAD |
Page <123> |
