List Your Mods: |
Page <1 1314151617 78> |
Joined: 29 Jul 2009 Location: MD Online Status: Offline Posts: 9065 |
Topic: List Your Mods:Posted: 10 Aug 2013 at 10:51pm |
Look into the rubberized cabinet mats to go under your cedar bathroom floor. That should take out the squeak.
ilthyn
Joined: 21 May 2013 Location: Alberta Online Status: Offline Posts: 66 |
Posted: 11 Aug 2013 at 3:19pm |
Thanks, Techntrek
We have tried that, but little change. I have to figure out why the bathroom floor creaks. It may be the curved edges of the cedar slat floor are not equally pressing on the shower floor. The cedar itself does not squeak when removed and stepped on.
TrinityTurret
Joined: 26 Sep 2013 Online Status: Offline Posts: 58 |
Posted: 13 Oct 2013 at 10:36pm |
DIANE!!! How did you install that safety handle...and can one be put on the door???
There's only one way...
TrinityTurret
Posted: 13 Oct 2013 at 10:50pm |
May I ask what kind of screws do you use to attach that wire shelf in your bathroom?
ilthyn
Posted: 15 Oct 2013 at 10:30am |
Thanks for the tips on the squeaky shower floor. I cut up an old rubber air mattress and put it between the cedar slats and the floor and it works real fine.
mtbmitch
Joined: 15 Sep 2013 Location: Boise, idaho Online Status: Offline Posts: 91 |
Posted: 26 Oct 2013 at 10:14pm |
Here are my rpod mods since we became the new used owners of a 09 151
Straightened out the wiring in the hot water heater/ main power distribution box put insulating foam around the water lines to quiet down the water pump and rotated the filter so it would not rub the floor. Sealed off the air leaks used spray foam around all the cut outs of doors, water lines and propane lines to add a better insulated trailer removed the dvd,tv radio combo and antenna removed the microwave, since we dry camp this was a 50 pound boat anchor for us added storage where the microwave used to be removed a 110 out let and installed a 12 volt outlet scraped the paint between the main ground points( where the battery negative wire is connected to the frame and where the ground wire from the frame that runs to the main power fuse block. insulated and installed car heating pads(ebay) and wired in to main fuse panel. added a 400 watt inverter to run stuff added a 2 outlet 12 volt/usb to charge the phones, etc next is to relegate the 22 pound table to the trash and make a light weight old school post style table |
enjoy the fresh air
Posted: 27 Oct 2013 at 10:08pm |
Are the heating pads on your water tanks?
mtbmitch
Posted: 28 Oct 2013 at 11:30am |
I used these heat seating pads
http://www.amazon.com/Universal-Carbon-Fiber-Heater-Installation/dp/B002QYAL2U and glued the dense pink r30 foam over them along with foil tape. They take some power so I upgraded the battery. Luckily one of motorcycle suppliers carriers the Deka battery. So the tongue weight is now a bit more with a group 31 battery but only running one propane tank since that is all we need for a 2 or 3 day trip. Also since check the ground attach points on the frame, they did not remove the paint and there was a bad voltage drop between the battery and the main power distribution box. |
enjoy the fresh air
sailo25
Joined: 21 Mar 2013 Location: Michigan Online Status: Offline Posts: 37 |
Posted: 28 Oct 2013 at 6:17pm |
Did you leave the A/C on the roof, I am thinking of removing mine and wandering if you have considered this. I also removed my micro and am considering removing the entertainment center and adding a auto am/fm cd player. I am trying to lower the wind resistance.
mtbmitch
Posted: 28 Oct 2013 at 10:58pm |
No AC needed here in Idaho, we can escape the heat in an 1-2 hour drive. So the used 151 pod did not have AC when we bought it last month.
enjoy the fresh air
