arkieguy
Topic: towing vehicles? Posted: 05 Oct 2013 at 8:33am |
We tow our pod with a Toyota Tacoma dbl cab with tow package. On our most recent trip we got 14 mpg with pod (182g) , all our stuff and two kayaks on top. We towed through the ouachita mountains with no struggles. Great option if you don't want a full size truck.
hogone
Posted: 06 Oct 2013 at 8:15am |
My F150 has 35,000 miles. Was considering changing the tranny fluid. Would it be unwise to just drain the fluid, add drain amount (new fluid) back in and not replace the filter? hogone
Jon & Pam
2013 RP177
2023 F150
2017 HD Streetglide
CHEESEHEAD
Posted: 06 Oct 2013 at 8:44am |
The mechanic I use has a machine that hooks in line with the cooler lines and he tells me that it allows him to remove the fluid from the converter as well as the transmission, flush the system then replace fluid along with some additives. He has taken care of my vehicles for some years successfully, so that is the route I will use. YMMV
2011 R-Pod 177
2010 Ford F-150
hogone
Posted: 06 Oct 2013 at 9:14am |
thanks for the info, and just to confirm, no new filter correct? how many miles on your first change? hogone
Jon & Pam
2013 RP177
2023 F150
2017 HD Streetglide
CHEESEHEAD
CharlieM
Posted: 06 Oct 2013 at 9:23am |
For what it's worth, I just went through that drill on my Honda Pilot at 35k. Honda recommmens changing transmission oil at 30k. The dealer just does a simple drain and refill the first time at 30k and a complete flush the next time. And, comntrary to what I had been reading, the Honda has no filter. If your Toyota has one my guess is you'd replace it every other fluid change. Only my guess.
Posted: 06 Oct 2013 at 1:36pm |
Good question. I will have to ask him next time I am at his shop,
2011 R-Pod 177
2010 Ford F-150
