SchipperPod
Topic: which r-pod should I buy? Posted: 11 Sep 2013 at 4:21pm |
What do I use for a voltage number? I'm still really confused. If I plug in with a 30 amp service at a site, you're saying that that's divided between outlets? I guess if someone could tell me, for most camp sites with electrical hookup, what are my amps, what's my voltage, and how many watts I can then use... - I don't even know enough to ask this question correctly.
Happy tails and trails!
Teri & Jeff Black
Plus 4 Schipperkes: Kodi, Jessie, Maggie & Bear
2014 R-Pod 178
2013 Santa Fe Sport Turbo
Posted: 11 Sep 2013 at 4:38pm |
In this case.. 1800 watts / 120 volts = 15 amps. That means, while your blow dryer is running, nothing else on that circuit can be on.
You have 30 amps of 120v available. But you can't use all 30 amps on one circuit. It is divided up into several circuits, and none of them can draw more than their breaker allows, without tripping said breaker.
Just like at home, you have the CAPABILITY to draw more amps then you can have (likely 200 amps at 240v) but nobody turns EVERYTHING on in their house, or pod at once..
SchipperPod
Posted: 11 Sep 2013 at 4:56pm |
furpod and Sleepless, thank you!! I'm finally starting to get it!
Teri & Jeff Black
2014 R-Pod 178
Seanl
Posted: 11 Sep 2013 at 5:03pm |
Originally posted by SchipperPod
What do I use for a voltage number? I'm still really confused. If I plug in with a 30 amp service at a site, you're saying that that's divided between outlets? I guess if someone could tell me, for most camp sites with electrical hookup, what are my amps, what's my voltage, and how many watts I can then use... - I don't even know enough to ask this question correctly. |
Okay a little electrical theory. Power ( which is measured in watts) is Current (amps) times Voltage. The formula is written like this P=IxE. So if you turn the equation around then I (current)= E (voltage)/P(watts). when you plug into the post at a campground the campground provides you with 120 Volts at 30 amps. This goes into a distribution panel in your Pod. This is like your breaker panel in your house. At the distribution panel the electricity goes through breakers to different circuits in the trailer. The plugs are on a 15 amp breaker so you can run anything that uses less than 15 amps on that circuit. So to calculate how many amps an appliance uses. you take the watts, in this case 1800 for you hair drier and divide it by the Voltage. so 1800/120=15 amps. So if you have nothing else plugged in you can use your hair drier. If you do overload the circuit then all that happens, as has already been said, is you trip a breaker that has to be reset.
SchipperPod
Posted: 11 Sep 2013 at 5:11pm |
Seanl, thanks!! That's the clearest it's ever been explained to me! And it makes sense even a blonde can follow.
Teri & Jeff Black
2014 R-Pod 178
Paige
Posted: 11 Sep 2013 at 6:21pm |
You should be able to run the dryer, but nothing else while you are drying your hair. We have a toaster and a four cup coffee maker. If we run both we blow the circuit. But no biggie, we just reset the circuit and choose which appliance to use.
Paige and Pete
2010 177 - RPug
2012 Rav (six cylinder)
New York & Florida residents
Sleepless
Posted: 11 Sep 2013 at 6:32pm |
Quite often the voltage at a campground can be under the standard of 120 volts. It it is too low, it can conceivably damage sensitive electrical devices or affect the operation of your air conditioner. I always keep a digital voltmeter that plugs into one of the pod's outlets. I began using an analog voltmeter years ago for that purpose, back in the days when brownouts were more common. I take no chances with my electronics.
Bob
2014 R-Pod 178 (OUR POD)
2009 Chevrolet Avalanche
SchipperPod
Posted: 11 Sep 2013 at 7:00pm |
I like that idea, Bob. If I get a voltmeter, should I be looking for 120 on the meter when plugging it in? If I see less than that, does that mean I should use my generators instead? If you could help me know what's safe or too low, I would appreciate it. Thank you!
Teri & Jeff Black
2014 R-Pod 178
SchipperPod
Posted: 11 Sep 2013 at 7:06pm |
Also, just want to let the group know, I put a deposit down today on the 2014 R-Pod 178, fully loaded, with the Crown package and the R-dome in Pebble! $13,900 for everything. It doesn't have the axle riser, but I think I'll add that once I get it back to Utah. I'm excited!!
Teri & Jeff Black
2014 R-Pod 178
kymooses
Posted: 11 Sep 2013 at 7:25pm |
The crown package options are very nice. And I very much like the new Pebble coloring! Nice new options! COngratulations
