curieuse
Calendar Event: Awning gets out of track Posted: 30 Jul 2013 at 5:08pm |
We have had a problem with our awning getting out of it's track, seems to be to loose in an area of the track, has anybody had the same problem and found a solution?
many thanks
Manon
Sleepless
Posted: 30 Jul 2013 at 5:35pm |
I read in an earlier post where someone used pre-set vice grips to "tighten" up the awning slot.
Bob
2014 R-Pod 178 (OUR POD)
2009 Chevrolet Avalanche
curieuse
Posted: 30 Jul 2013 at 8:06pm |
Thanks Bob, we were a little afraid of breaking the slot, if you come by the post again let me know I did not find it yet.
Manon
kymooses
Posted: 31 Jul 2013 at 8:58am |
Are you talking about your R-Dome?
Is this something that came with your Pod or did you buy it afterwards?
I wonder if perhaps you have the wrong size dome for your track possible?
Posted: 31 Jul 2013 at 8:10pm |
+1, may be the wrong welt size for your track.
curieuse
Posted: 01 Aug 2013 at 8:05am |
Thanks to both of you, the dome came with the pod when we bought it, how can we know if we have the right one? It seems to be looser in one area of the slot and it seemed to be OK at first. It is not wide enough to attach both sides on the sides of the pod with the suction cups, we always end up having to attach one side to the front of the pod.
Thanks for your help,
Manon
Posted: 01 Aug 2013 at 9:13am |
I don't think there is anything to let you know other than how tightly it fits in the track. If only one section feels loose I would take the advice to slighly narrow the opening in that area.
Sleepless
Posted: 01 Aug 2013 at 9:59am |
Originally posted by curieuse
Thanks Bob, we were a little afraid of breaking the slot, if you come by the post again let me know I did not find it yet. |
I did a search of both this forum and the other one but the post did not show up. The thread involved modifying the larger-size slots to accommodate the smaller-sized one. I recall that one member actually ordered a proper sized slot from Forest River while others used various methods to "squeeze" their existing slots down to the smaller size for their domes. The one that sticks in my mind, which seems the safest and would give a uniform opening, is the use of vice grips. I added the part about pre-setting the vice grips to insure the proper opening was achieved for the entire length of the channel. Perhaps another member will remember more about this, but the process seems simple enough. I don't see any danger of breaking the channel. It is aluminum and will bend quite easily. Bob
TIDALWAVE
Posted: 01 Aug 2013 at 10:51am |
 If you use a vice-grips to 'set' the best width of the track...let the Pod sit out in the sun for awhile so that the plastic of the track can soften slightly before using the grips. Cold plastic would have a greater chance of cracking. After the grips have adjusted the track width...I would spray some cold water on the track to help harden the plastic.
TIDALWAVE
Seanl
Posted: 01 Aug 2013 at 1:01pm |
The track on mine is aluminum.
