Outbound
Topic: pros and cons of risers. Posted: 11 Jun 2013 at 7:47am |
In four years owning my r-pod, I've never installed risers. I've only once scraped the stabilizers and that was on a friend's steeply sloped driveway.
TerryM
Posted: 11 Jun 2013 at 6:59am |
I ordered mine with the riser. I sometimes take my camper off road so I wanted the extra height to protect the holding tanks etc. The only negative, as was mentioned, was the R-Dome doesn't fit as it is supposed to. But it does still work.
Terry
Posted: 10 Jun 2013 at 7:16pm |
As far as cons.. you will need a new hitch to keep the pod level when towing (assuming it is level now).. and the r-dome will fit a bit funny after the lift, if you use one.
Kickstart
Posted: 10 Jun 2013 at 7:15pm |
After peeling off a stabilizer entering a gas station, I figured we should have the risers installed. A con for us is the additional step height, as my wife's back is encased in a titanium cage and she doesn't do well with much height on steps. We added a second entry step, which actually decreased the step height for her, even with the risers.
'12 Toyota Tundra
'05 Sportster (half a Harley)
Retired-We're on Beach Time!
Posted: 10 Jun 2013 at 6:59pm |
The only negative I can see is the cost. After loosing one of the stabilizers I had them put on this spring and all is well. Plenty of room now and it pulls fine. I should have had it done when I bought the Pod.
2011 R-Pod 177
2010 Ford F-150
21grandma
Posted: 10 Jun 2013 at 6:35pm |
 We would like to get our 177 into our back yard, but our driveway is down hill. Are risers the way to go, and what are the negatives of risers.
21grandma
