  New Posts New Posts RSS Feed: two propane tanks
Topic Closedtwo propane tanks
bc matell View Drop Down
Direct Link To This Post Topic: two propane tanks
    Posted: 19 Apr 2013 at 5:25pm
Has any one converted the one propane tank holder to two? Our 177 has space for only one propane tank. Thank you for replys. Big smile
TV 2012 Toyota Tacoma 6 cyl
Misha the Lab
Loving life and living it!
Tars Tarkas View Drop Down
Direct Link To This Post Posted: 19 Apr 2013 at 9:39pm
  I made the conversion last weekend.  I went pretty much all the way with the addition of an auto switchover valve & regulator so that when the first tank is empty the second one will seamlessly take over.  You don't have to do that -- the valve was nearly half the cost.
  Probably the hard part was getting rid of the original tank holder that was welded to the tongue.  It took a while with a Sawzall and a side-grinder to get rid of that.  Then some paint, of course.
  I should have made a list of the parts, where they came from and what they cost.  Most if not everything is available from Amazon.  I needed the two-tank holder, and two new hoses to run from each tank to the switchover valve.  Those were about  $25 and $15 x 2.  The tank holder bolted right on to the existing holes for the single tank straps.  And you need some teflon tape.  The whole job, not counting time for the paint to dry, took about an hour.
  If you don't want to manually switch tanks when one runs out, the switchover valve was around $50.  I ordered one on Amazon from Grady's but told them to keep it when they hadn't bothered to ship it a week after I ordered it, and I was glad I did considering what I considered was not a great attitude toward customer service.  There are plenty of other places to pick up a valve.  The one I got is branded Mr. Heater and is made in Italy.
  Finally, I think I spent about $25 for a two tank cover from Camping World.
  Other than cutting and grinding the old tank holder off, the hardest part was waiting on FedEx Smartpost to deliver the components.  I can't wait for people to wise up to FedEx Smartpost and kill that "service".
Alex&Marie View Drop Down
Direct Link To This Post Posted: 20 Apr 2013 at 7:04am
We just installed this mounting bracket for two 5 gallon (20 pound) propane tanks on our RPOD 177. Easy installation. I didn't grind off the old single bracket, just installed the double one on top of it. I was able to use the same mounting holes in the frame that had been used by the original bracket too.
this is where we bought it - I could not find one locally.
http://www.rvplus.com/manchester-tank-5-gal-dual-rack-comp-1801.html
ProductQuantityUnit priceSubtotal
Manchester Tank 5 Gal Dual Rack Comp 1801
Code: CS-50021
1$20.99$20.99
Subtotal: $20.99
Shipping cost: $9.73
Total cost: $30.72
Alex and Marie
2012 R-pod 177
2006 Toyota Tundra
Camper Bob View Drop Down
Direct Link To This Post Posted: 20 Apr 2013 at 8:00am
We had a second tank and auto cutover added before we picked up our Rpod.  On reflection, we always use full hookups and with a small ceramic heater, we hardly use any gas at all.  We do travel with the reefer on electric and don't do any serious cooking inside.  We did add a quick connect gas adapter on the hitch to use with our gas stove.  Works great and don't have any of those small gas "bombs" rolling around in the storage areas.  Since its just the two of us I would suggest not installing the second tank since we hardly use much gas at all.  When we camped years ago with our sons, the hot water disappeared in minutes with the shower.  Safe Travels.
Camper Bob and Camper Sue
2013 Rpod 171HRE(ORPod)
2016 Lance 1685
2015 Nissan Pathfinder
CharlieM View Drop Down
Direct Link To This Post Posted: 20 Apr 2013 at 12:50pm
All comments are good and correct. However, one extra point. I had the two tank conversion performed by our dealer before I picked up our RP-172. The old single tank mount was removed and the new  twin tank mount installed. One thing I found when I got it home. I had the E2 WDH installed (I consider this a requirement), but had to re-adjust it at home. The dealer really blew this part of the set-up.
The E2 installation requires a maximum of 27 inches from the hitch ball to the friction brackets. The dual tank brackets, as mounted, prohibited this maximum distance. As it turned out it was OK but the tank bracket should have been mounted more forward to add some margin to this installation. This may preclude using the existing holes. However, drilling new holes is no big deal. It may also require a linger hose: again, no big deal.
Overall the dual tanks are good if you're camping without electricity (fridge, hot water, and furnace on gas), but would be unnecessary if you have electric hookups.
Happy podding,
