  New Posts New Posts RSS Feed: New RPodder, quick question
Topic ClosedNew RPodder, quick question
Direct Link To This Post Topic: New RPodder, quick question
    Posted: 19 Mar 2013 at 9:04pm
Also you don't need to burn the stove for more than 10 seconds once you get it lit.  At that point the lines have been purged as much as you are going to get.   I agree you need to go outside immediately after selecting gas mode.  On mine I think it waits about 10 seconds before trying to light the first time.
EEBowHunter View Drop Down
Direct Link To This Post Posted: 08 Apr 2013 at 2:43pm
Update:  I figured out what I was doing wrong...turns out all I needed to do was power cycle the refrigerator on the propane setting and when I turned it on the igniter lit within a second or two and it was happy all weekend.  Got pretty dang cold too! Smile  I appreciate all the help!
bhamster View Drop Down
Direct Link To This Post Posted: 08 Apr 2013 at 3:20pm
ConfusedI'm confused... what were you doing before?
Direct Link To This Post Posted: 08 Apr 2013 at 3:31pm
The pod stays out at my property permanently.  When we leave & button everything up I was disconnecting the battery and storing it.  Well when I would connect the battery the refrigerator would power up but it had never been turned off prior to disconnecting the battery so for some reason it just never tried to ignite the pilot.  It wasn't until after I power cycled it (with the battery connected) that it tried to ignite the pilot.
Direct Link To This Post Posted: 08 Apr 2013 at 4:29pm
Interesting... so if you lost power for some reason (in this case, you disconnecting it) then it doesn't try to start again?
Direct Link To This Post Posted: 08 Apr 2013 at 8:34pm
Huh, I'll have to try this on mine.
Direct Link To This Post Posted: 08 Apr 2013 at 8:38pm
bhamster...that's what I was able to deduce.  The lady I bought the pod from kept the battery disconnected and stored in the trailer when it wasn't in use.  I just followed her example but noticed that every time I connected the battery and went inside the trailer the refrigerator was on but when switched over to propane would never attempt to ignite.  Now if I can only fix this "singing"/"pinging" propane regulator it'll be good as new Big smile
Keith-N-Dar View Drop Down
Direct Link To This Post Posted: 08 Apr 2013 at 9:38pm
Maybe you can teach it a new song...
2011 R-Pod 177
2010 Ford F-150
Direct Link To This Post Posted: 09 Apr 2013 at 9:16pm
Make sure you hook up the battery and the pod to charge it overnight at least every 30 days, when its is warm.  In the coldest months you can get away with 2-3 months.
Many of the earlier pods had to get the regulator replaced due to pinging under high load - mine included.
Direct Link To This Post Posted: 10 Apr 2013 at 8:01pm
techntrek,
I contacted Susan Thornberg at Forrest River regarding the pinging issue and she said it was a known issue and related to the pigtail/regulator.  Fortunately she was nice enough to offer to send me replacement parts gratis Smile  Point taken on the battery...will do.  Much appreciated for the information Smile
