  New Posts New Posts RSS Feed: Winterizing without anti-freeze
Topic ClosedWinterizing without anti-freeze - Event Date: 28 Dec 2012
this_is_nascar View Drop Down
Direct Link To This Post Calendar Event: Winterizing without anti-freeze
    Posted: 05 Jan 2013 at 8:41am
Originally posted by tsunami123
The first fall I had my Pod, I planned on using an air compressor to blow out my water lines, followed by pumping RV antifreeze through them.  After I blew out the lines...I had a family emergency, so I wasn't able to get back for a couple days to add the antifreeze.  When I did...the air compressor was still hooked up to the Pod.  For some reason...I ran the compressor again (even tho' I had blown out what I thought was all of the water...no liquid spraying out).  To my surprise several good blasts of water jetted out of the faucets.  I think that there was a sufficient coating of water on the inside of the pipes so that after a day or two liquid had accumulated at one or more low spots.  I don't know if this small volume of water would have been enough to crack a valve or not.  But from then on...I always add antifreeze after blowing out the pipes.
I really don't like the taste left in the pipes in the Spring so I blow out the antifreeze, followed by flushing with clean water and then I make up a couple of gallons of baking soda water and pump it into the pipes and then let it sit for a day or two. Then I flush the soda water...and the bad taste is gone.
... and that was with using a compressor.  The OP used a hand-pump, which would have push out and dried-up even less from the system.  I know some feel I'm being anal on this subject.  I just hate seeing someone incur an un-needed expense and inconvenience in repairs.
"Ray & Connie"
- 2017 R-Pod RP-180
Pod People View Drop Down
Direct Link To This Post Posted: 05 Jan 2013 at 1:44pm
After reading the comments following my post, I added antifreeze to my system. That's the nice thing about forums like this-we all learn from each other.
Thanks
Vann Evans
ReddOrion View Drop Down
Direct Link To This Post Posted: 11 Jan 2013 at 2:01pm
I don't know if the picture will show up, but below is a combination of the two previously shown blowout solutions. It is the Camping World blowout hose with literally $4 of parts from Home Depot's air tool department. My mini compressor has a reg on it, so that part is covered.
uploads/1609/Blowout_Valve_-_reduced.JPG
Jason & Kim
2013 RP-177 HRE
2005 Tahoe LT
Direct Link To This Post Posted: 11 Jan 2013 at 2:20pm
One more try... Below is a combination of the two previously shown blowout solutions. It is the Camping World blowout hose with $4 of parts from Home Depot's air tool department. My mini compressor has a reg on it, so that part is covered.
Jason & Kim
2013 RP-177 HRE
2005 Tahoe LT
