  New Posts New Posts RSS Feed: Sort-of Antenna Review
Topic ClosedSort-of Antenna Review
dsmiths View Drop Down
Direct Link To This Post Topic: Sort-of Antenna Review
    Posted: 27 Nov 2012 at 7:30pm
P&M, make sure the preamp is turned on, there is a small green led light that shows its on, if not you will get poor to no reception. On our 172 its in the cabinet above the stove.
Dane and Donna Smith
2011 RP-172
lift kit
Keith-N-Dar View Drop Down
Direct Link To This Post Posted: 27 Nov 2012 at 7:32pm
The skin on the roof is fiberglass and shouldn't cut down the signal much.  I think the frame is aluminum and that could.
I am not into the TV much, but when I have had the amp on (and most of our first year I didn't know it was turned off) I got fairly good reception.  If I had the choice I would have opted out of the TV/Antenna and saved the money.
We looked at three 177s when we got ours (at two dealers).  Two were alike with all the options.  One was stripped completely (no TV, no microwave/convection oven, no air conditioning).  WE may have taken the stripped on if it had air, but we sweated out to many nights on the plains in the summer to do that.
To each their own I guess.
2011 R-Pod 177
2010 Ford F-150
Paige View Drop Down
Direct Link To This Post Posted: 28 Nov 2012 at 7:46am
There is a preamp? Where is it in the 177?
Paige and Pete
2010 177 - RPug
2012 Rav (six cylinder)
New York & Florida residents
Direct Link To This Post Posted: 28 Nov 2012 at 9:11am
It is in the box that the TV is mounted to.  Open the door and you will see it with the antenna cables coming to and from it.  It has an led that is also a push on/push off switch.
2011 R-Pod 177
2010 Ford F-150
Direct Link To This Post Posted: 28 Nov 2012 at 4:31pm
Found it! Could explain why the tv didn't pull in any channels,,,not that we really cared to watch. Thank you!
Paige and Pete
2010 177 - RPug
Direct Link To This Post Posted: 28 Nov 2012 at 6:37pm
Also check to be sure that the coax cable connectors are tight.  On mine one was so loose that it fell off when I touched it.  Not good for reception.
It still is what it is.  We didn't get ours for TV watching.
2011 R-Pod 177
2010 Ford F-150
P&M View Drop Down
Direct Link To This Post Posted: 29 Nov 2012 at 3:14pm
A pre-amp button?  And it isn't on the unit itself, but somewhere near the plug?  Don't recall seeing one but will write this down in my log book so that I can look for it the next time I swing by the storage lot.  That would definitely explain why I wasn't getting any channels ... thanks!
P & M ... and Comet too!
2012 171 -- The Monkey Pod
2018 Ram 2500
Direct Link To This Post Posted: 29 Nov 2012 at 4:18pm
The amp switch is in the cabinet above the cooktop in the 172, I tkink it is the same in the 171.
bhamster View Drop Down
Direct Link To This Post Posted: 30 Nov 2012 at 1:03pm
Yeah, it's the same in the 171. It's also worth mentioning that the amplifier has 12V power, which makes it super-easy to put in one of these instead http://www.amazon.com/Winegard-RV-7042-White-Plate-Supply/dp/B000GGL4CG and get an extra 12v outlet.
Direct Link To This Post Posted: 30 Nov 2012 at 11:09pm
Another note on it using 12 volts, if you are bookdocking make sure you turn it off when not in use.
