RPodWeGo
Topic: winterizing Posted: 08 Nov 2012 at 12:41am |
My 177 HRE 2012 has two low point drains located behind slide out side tire with a blue and red cap.
RPodWeGo
RPod 177
04 v8 Toyota 4Runner
marwayne
Posted: 06 Nov 2012 at 11:00pm |
Well I have two low point tubes, both caps are black on my 172.
Posted: 06 Nov 2012 at 10:20pm |
Ah. Well, mine doesn't have color anywhere, even in tape form.
Footslogger03
Posted: 06 Nov 2012 at 6:25pm |
Odd, there like 'Slogger said there should be one for each side of the water system. However, mine only has gray caps and not blue/red.
My caps are grey ...but there is blue and red tape on the bottom edges of the 2 drain lines.
'Slogger
Livin' the Dream ...'Slogger
Posted: 06 Nov 2012 at 6:19pm |
thadd
Posted: 06 Nov 2012 at 4:52am |
Originally posted by Paige
We have a 177 and have only located one low point drain...is that because it is a 177? |
What year is yours? My 2012 177 only has one drain too.
Footslogger03
Posted: 05 Nov 2012 at 9:41pm |
There should be 2 and they should be right next to each other. One is colored blue and the other red. They should both have threaded caps on them.
I have a 177 and I have 2.
'Slogger
Paige
Posted: 05 Nov 2012 at 8:35pm |
Paige and Pete
2010 177 - RPug
2012 Rav (six cylinder)
New York & Florida residents
Posted: 05 Nov 2012 at 7:44pm |
A note on using air to blow-out first. The last few years I always forgot how much extra RV antifreeze I had from the prior year, so I would come home with another gallon or two - to find I still had 1 or part of one. This year I thought I had 1 3/4 gallons left from last year but when it came time to winterize I found I only had 3/4. Usually I use at least 1. I decided to spend more time getting as much water out of the pipes using the air, and to leave the sink and shower traps for last.
In the end I had exactly enough using that 3/4 gallon to clear the pipes - including my aftermarket outside shower - and then add enough to 1 of the 2 traps. I was amazed, but I know spending more time with the air helped. For now I added some winter-grade windshield washer fluid to the other trap (knowing it is plastic and rubber safe), but I've been warned that since it is mostly alcohol it will evaporate so I should replace it with RV antifreeze before the real hard freeze sets in.
thadd
Posted: 05 Nov 2012 at 6:51pm |
Originally posted by wildflowerz
I just downloaded the app to check it out. I like having it on the iPad! My husband is asking for a de-winterization one now.Thanks! |
I'm planning on it. It's a little tedious to create the checklists, but if other people find them useful I'll definitely do it!
Do you think it would be helpful to have pictures along with the steps or are things self-explanatory enough with the text-only descriptions?
