  New Posts New Posts RSS Feed: New - Rpod 178
Topic ClosedNew - Rpod 178
Seanl View Drop Down
Direct Link To This Post Topic: New - Rpod 178
    Posted: 18 Oct 2012 at 8:30am
Originally posted by Paige
Finally, they got smart with the entertainment center!!! Wonder how long the dinette table is.
The dinette is the same size as the one in my 173 so the table is probably about 40 to 42 inches long. I will measure mine tonight.
Direct Link To This Post Posted: 18 Oct 2012 at 11:14am
Are all of the cusions on the U Dinnette removable so you have the full length for sleeping?  I would hope so.
Direct Link To This Post Posted: 18 Oct 2012 at 12:21pm
yes they are and when you do you get a sleeping surface the size of a short queen. I don't take the cushion backs for the corners with me when I travel because I Usually leave the bed down and the cushions just get put in the TV because there is no room for them in the camper.
This is basically a 182G with a queen bed instead of the garage.
It is lighter than the 182G though about 200 lbs heavier that my 173 that will be the weight of the slide I think.
Dry Hitch Weight225 lbs. (102 kg)
Unloaded Vehicle Weight2,205 lbs. (1,000 kg)
GVWRTBA (TBA)
Cargo Carrying Capacity1,003 lbs. (455 kg)
Exterior Length18' 4" (5.6 m)
Exterior Height9' 6" (2.9 m)
Exterior Width96" (2.4 m)
Fresh Water Capacity36 gal. (136 L)
Gray Water Capacity35 gal. (132 L)
Black Water Capacity35 gal. (132 L)
Awning SizeTBA (TBA)
novapods View Drop Down
Direct Link To This Post Posted: 17 Jan 2013 at 6:24pm
Hi
I'm planning on buying the 178 and wonder if you've seen it with the 19" flat screen TV? Does it have a cd/am/fm radio/ dvd too, where the tv is? I'm confused re this. One dealer said it is a flat screen and radio etc is included too.
( not the Combo unit) Another said it is just a tv, but we could also order the Combo unit to have cd & radio.We were told there are inside/ outside speakers. Anyone know which entertainment centre is correct?
Thanks!
Novapods
2013 rpod 178
2010 Toyota Sienna
HavaPod View Drop Down
Direct Link To This Post Posted: 19 Jan 2013 at 9:37pm
The dealer we purchased our R-Pod 177 from in December (Poulbo in Tacoma, WA) did have a 178 on the lot at that time that we looked at.  We thought long and hard about the two but decided on the 177 because it was a bit lighter and a bit shorter than the 178.
Steve and Peggy Thorndill
HavaPod
2013 R-Pod 177
Tacoma, WA
Direct Link To This Post Posted: 19 Jan 2013 at 9:48pm
Additional comment -
After looking more carefully at the specs a couple of posts up, and comparing those to ones on the 177 in a brochure we have,  I'm not so sure I'm right about the 178 being longer and heavier than the 177??
HavaPod
2013 R-Pod 177
Tacoma, WA
Direct Link To This Post Posted: 20 Jan 2013 at 9:28am
Hi HavaPod,
Do you remember what the entertainment system was in the 178 you checked out? Was it the Combo unit, or the 19" flat screen by the door area. If so, did the larger TV have a radio/cd system mounted by it too?
Also ,FYI the 178 ship weight is 2535 lbs., length total 20', hitch wt. is 257 lbs.
Novapods
2013 rpod 178
2010 Toyota Sienna
Direct Link To This Post Posted: 21 Jan 2013 at 1:38pm
Hello Podwannabees,
My wife and I can't recall for sure, but believe it might have been the same type of combo unit with the small TV that the 177 has.   I've sent an email to our salesperson to see if he can check it out for sure and when he gets back to me I'll let you know for sure.
HavaPod
2013 R-Pod 177
Tacoma, WA
Direct Link To This Post Posted: 21 Jan 2013 at 4:58pm
HavaPod,
Thanks so much for your reply. We have finally got all the info ironed out and are clear on what our 178 will have.
We decided to opt out of either tv system and buy our own 19" tv/dvd combo, as our dealer suggested, & have it installed when we go to get our pod. There's a place to install it by the door entrance.
Can't wait to get our new pod!!
Novapods
2013 rpod 178
2010 Toyota Sienna
