this_is_nascar
Topic: Anti sway or Equalizer hitch ?? Posted: 11 Sep 2012 at 3:22pm |
Thanks guys. That makes me feel a bit better. I was at Sears and saw torque wrenches that only went up to 250-lbs or so. I'm trying to spend as little coin as possible. When you say a 1/2" breaker bar, is that just a straight bar with the socket thing on the end that's non-rachetting? Since I won't bother looking for a torque wrench, I'm not sure whether to try a 1/2" socket wrench or this breaker bar thing.
'Slogger, this is going on my Tacoma as well. Any hints or suggestions or things I should be aware of? Did the standard sized piece that goes into the Taco hitch fit OK or did you have to swap that out for a different sized piece?
"Ray & Connie"
- 2017 R-Pod RP-180
Seanl
Posted: 11 Sep 2012 at 3:51pm |
Yes I it is non ratcheting socket bar. I would have used the ratchet but I have broke a couple of ratchets that way.
this_is_nascar
Posted: 11 Sep 2012 at 4:02pm |
OK, thanks. I'm looking for a "how-to" video on YouTube or somewhere to show the installation of this Fastway E2. All I've been able to find are those videos for the Equalizer. Although similar, not exactly the same. I'm surprised the Fastway site doesn't have a how-to video for the hitch installation.
"Ray & Connie"
- 2017 R-Pod RP-180
Footslogger03
Posted: 11 Sep 2012 at 4:05pm |
No tricks I can think of. I presume you are taking about the "shank" - - and yes, the standard shank fit perfectly. Not sure which model Taco you have and what your ball height off the ground is, but on mine I had to orient the shank with the longer end (vertically speaking here) downward. The top of the hitch head is flush (or darn near) with the top of the shank (ie ...I used the top hope in the side of the hitch head for the upper bolt. I ended up with a piece of vertical shank that sticks down about 8" or so below the hitch head, but it hasn't caused any problems. I have yet to "bottom out" while towing the Pod. I left the hitch head/shank assembly on the Taco after our last trip and when pulling itno our ACE Hardware parking lot I did hear the hitch bang - - but the street is REALLY crested high and there is a huge dip at the curb before you start up their driveway, so that's a worst case scenariio.
Hope that helps. I can post a pic of my assembled hitch (off of the truck) if you want.
Oh, and the bar (breaker bar) I bought to use with that humongous socket is just a long handle with a 3/4" socket base on it. I bought the 1/2" -> 3/4" adapter at first because I already had a 1/2" breaker bar and my torque wrench is 1/2" drive - - but the handle length on the 3/4" breaker bar is longer for better leverage and it's made of overall thicker steel.
'Slogger
Livin' the Dream ...'Slogger
this_is_nascar
Posted: 11 Sep 2012 at 4:23pm |
Thanks, that helps. If you wouldn't mind posting pics, that would be great. I have a '07 TRD Off-Road, 4x4 model of Tacoma. So, is that thin-walled socket a 1/2" drive or 3/4" drive? Now I'm not so sure.
"Ray & Connie"
- 2017 R-Pod RP-180
Footslogger03
Posted: 11 Sep 2012 at 4:25pm |
It should be 3/4" on that socket. Give me a few minutes to find that pic and I'll upload it.
'Slogger
Footslogger03
Posted: 11 Sep 2012 at 4:41pm |
OK ...here is a pic of my Equalizer WDH assembly (off of the truck). Disregard those "wings" pointing upward from the shank shaft. Those are the arms for my "Rock Tamer" mudflaps ...
'Slogger
this_is_nascar
Posted: 11 Sep 2012 at 4:43pm |
Thanks. I was getting ready to ask "what the hell are those wingy things sticking up? :)"
"Ray & Connie"
- 2017 R-Pod RP-180
this_is_nascar
Posted: 11 Sep 2012 at 4:44pm |
The reason I "assumed" 1/2", was because that's all I saw at Sears. Nothing in 3/4" that I could see.
"Ray & Connie"
- 2017 R-Pod RP-180
Posted: 11 Sep 2012 at 4:45pm |
My box came all busted up, too. I don't know how I wasn't missing any pieces, like the L brackets.
While the E2 and Equalizer aren't identical, they are close enough that any video made for one should be OK for the other.
