TerryM
Topic: Picture help Posted: 25 Aug 2012 at 3:29pm |
Does anyone have a program that would allow you to make some changes to this picture?  If so I can explain what I want done. Terry
Seanl
Posted: 25 Aug 2012 at 4:56pm |
I could but it would depend on what you wanted done whether I had the skill to do it.
TerryM
Posted: 26 Aug 2012 at 1:36pm |
The biggest thing is removing the background.
Terry
Posted: 26 Aug 2012 at 6:18pm |
Do you want the black changed to white on the background?
TerryM
Posted: 27 Aug 2012 at 7:59am |
No, I don't want any background. The reason is this; I plan on giving a copy of it to a locale company so they can make a plastic stick-on for the door of my F-150. I'm sure they can do it but the charge would kill me!
I talked to a place about doing it with paint but they wanted $800.00 to do it!
Terry
FuzzySproket
Posted: 27 Aug 2012 at 8:22pm |
If all you want to do is remove the black you can open it with MS paint. Change color1 to white, select the eraser, set the size. ![]() use the slide to change the view (bottom right) ![]() It will take a little time but it's your time, save often and most of all there is an undo button (top right) just in case. ![]() hope that helps,surely not the only or fastest way.
Tom & Cindy
2010 174 RPod
2013 Ford F250
Posted: 28 Aug 2012 at 2:16pm |
I can change the black to non-black pretty easy in Photoshop, but I'm not sure about making it transparent - which is what I believe is needed here.
bhamster
Posted: 28 Aug 2012 at 3:48pm |
How about this:
the background is transparent although your browser may show it as white
Posted: 28 Aug 2012 at 9:40pm |
That looks like winner to me.
TerryM
Posted: 31 Aug 2012 at 4:10am |
That last one looks pretty good. Thanks!
Terrry
