Forum Home Forum Home > General Camping > Cook'n With Gas
  New Posts New Posts RSS Feed: Best barbecue for RPoddingl
Topic ClosedBest barbecue for RPoddingl
betsypgarmy@yahoo.co View Drop Down
Direct Link To This Post Topic: Best barbecue for RPoddingl
    Posted: 30 Jul 2012 at 6:59pm
Thank you for all your suggestions!
Vallgrl
Direct Link To This Post Posted: 30 Jul 2012 at 9:13pm
I just moved this over to the cooking section.
kymooses View Drop Down
Direct Link To This Post Posted: 13 Aug 2012 at 10:34pm
Following up with some of the discussions.  I'm wanting to buy the Coleman LXE gril.  Only problem is that it's set up as a high pressure grill.  It has it's own pressure regulator attached.
Now on our Rpod we have a low pressure line already that comes from our main 20lb tank up front.  Since I can't then connect to a 2nd regulator I'm wondernig if anyone has any ideas.
Some forums have suggested just removing the regulator from the new grill but it seems then finding compatable connection pieces are an issue.  And I don't particulary want to run a new line that proceeds the regulator at the front of the Pod either.
I don't think most of you have that existing propane line in the back of your trailers like we do so this might not help much but any suggestions are appreciated!
Direct Link To This Post Posted: 14 Aug 2012 at 4:43pm
I had high pressure and low pressure lines on my popup, the outside grill was a high-pressure line.  The high-pressure regulators are red if I remember right and you'll need one for your grill -  removing the regulator on the grill won't allow it to operate correctly, unless your pod already has a red regulator.
Direct Link To This Post Posted: 15 Aug 2012 at 2:04pm
Yuh I'm must today starting to realize the difference with the high and low pressure lines, and what exactly they mean.  The one that my Pod has to the back grill is a low pressure on.  So even if I could attach the new coleman grill without it's regulator it wouldn't matter because it would still be a low pressure line I guess.
How annoying!Ouch
Direct Link To This Post Posted: 15 Aug 2012 at 2:42pm
You'll have to add a high pressure regulator at the tank and run a separate line wherever you need it.  Probably easier to just take a 2nd tank and put it where you need it in-camp.  A 10 pound tank would be easier for this task, instead of another 20 pounder.
Westgl View Drop Down
Direct Link To This Post Posted: 24 Jun 2016 at 6:56pm
I have the weber Go anywhere LP version, I have a two LP tank setup, I bought a adaptor hose that screw on to my Lp tank and the other end to the BBQ, so I unhook one of my LP hoses form a tank, and install and screw on the bbq hose to it and I'm ready to go much better than using those small non refillable throw away tanks and less to take with me on a road trip,  less than 1 minute, and I ready to bbq
2010 RAV4 V6
2017 RPOD 179 Hood River Edition
Dual 6 volt Batts
Dual propane Tanks
Batt Disconnect
Bed leg extension
Dinette modification
Renogy 100w solar
Motorcycles several currently
Direct Link To This Post Posted: 24 Jun 2016 at 8:30pm
Weber Q - BTW  made in America.
Direct Link To This Post Posted: 24 Jun 2016 at 8:40pm
+1 for the Weber Q
onazip View Drop Down
Direct Link To This Post Posted: 11 Apr 2018 at 9:39pm
Can the Coleman roadtrip grill be hooked up directly to the propane connection on the R-Pod?  So we wouldn't have to use the small, disposable propane tanks.
2018 Tundra
2018 176t
