  New Posts New Posts RSS Feed: Propane & Battery usage
Topic ClosedPropane & Battery usage
this_is_nascar View Drop Down
Direct Link To This Post Topic: Propane & Battery usage
    Posted: 12 Mar 2012 at 7:28pm
Originally posted by jato
Outbound sums up quite well our experience with propane and  battery usage.  We use a lot of lights and battery usage is longer because we changed all our interior lights to L.E.D.'s which only consume about 1 watt/bulb and are brighter than the factory installed ones.  At that rate we could use all our interior lights at the same time and still use about the same amount of watts as 1 factory installed bulb!  We camped out at Glacier for a week last September and had mid-upper 30's each night, furnace worked quite a bit, we only used them a night as we were hiking during the day.  We managed to get 12 days out of 1 tank, that included a fair amount of stove use for cooking as well.  We were thankful to have 2 batteries, they would run to about 1/3 charge after 4 days, after that we switched to the other.
Can you share the details of the LEDs you installed and if you have a weblink, that would be great.  Thanks.
"Ray & Connie"
- 2017 R-Pod RP-180
Direct Link To This Post Posted: 12 Mar 2012 at 8:50pm
I changed out the existing 921 bulbs with ones from Putco, go to their website or you can purchase them in pairs for $ 20.00 at Amazon.  I got mine from Putco last April, but friends of mine ordered theirs from Amazon (got the exact same thing) for the same price, I guess the choice is yours.  Expensive up front BUT, use very little off your battery AND they will last a long time AND they don't give off any heat AND they give off more light than the factory installed 921's.
Direct Link To This Post Posted: 13 Mar 2012 at 7:36am
OK, thanks.  I'll check them out, but was also considering these.  The price is right and I've read of at least one other person using them.
"Ray & Connie"
- 2017 R-Pod RP-180
Direct Link To This Post Posted: 13 Mar 2012 at 4:00pm
Ray,
Those would work however the one I use is nearly identical in size to the one you have removed, so it will fit inside the lens nicely w/o having to fabricate an additional piece to hold it in place, as you would probably have to if you purchased the one you posted on your link.  My 1 cents worth.
Jim
Direct Link To This Post Posted: 13 Mar 2012 at 4:14pm
Thanks Jim.  I having difficulties finding the correct one from that website that you provided.  Can you narrow it down for me please?
"Ray & Connie"
- 2017 R-Pod RP-180
Direct Link To This Post Posted: 13 Mar 2012 at 4:30pm
Sure, the Putco page is hard to maneuver.  Do a google search.  Type in  " putco, led light bulbs for travel trailers."  On the result page go down about 5 entries to where it reads " putco  white 921 Type 360 degree Hi Intensity LED premium replacement light bulb."  Click on that link and you can read all the comments on the bulb.  You will read some negative comments but I am still sold on them 1 year after purchase.  A few of my friends who have purchased the same also have nothing but praise for the bulb.
Some replied these are dim but IMHO if they were any brighter, they would be too bright.  Price is $ 20.16/pair on Amazon.  You can order them - look at the upper right hand corner to order.  Hope this helps.
rid415 View Drop Down
Direct Link To This Post Posted: 13 Mar 2012 at 8:43pm
putco charge to much go to ebay better deal
Direct Link To This Post Posted: 13 Mar 2012 at 10:01pm
Couldn't find the putco bulbs on ebay, what kind of a deal can you get on a pair?
Camper Bob View Drop Down
Direct Link To This Post Posted: 13 Mar 2012 at 10:13pm
I am contemplating buying a 171 and have been watching both forums for months and have gotten some terrific info.  I was instructed to purchase some LED replacement bulbs on ebay.  I purchased 5 on anticipation of buying a 171.  They were .99 each, for a 36 leds per bulb.  They are sent from China and others who had purchased them were thrilled.  Great light output and certainly less than the $20/bulb from other sites of Camping World.
Camper Bob and Camper Sue
2013 Rpod 171HRE(ORPod)
2016 Lance 1685
2015 Nissan Pathfinder
Kickstart View Drop Down
Direct Link To This Post Posted: 14 Mar 2012 at 12:46am
Hey Nascar Ray, I replaced all of our Pod's 921's with the exact bulbs from E/Bay that you're considering. They don't put out quite as much light as a 921, but are perfectly adequate for reading. They install very quickly with the included adapters and tape, and don't produce the seemingly almost dangerous heat that the 921's do. Longevity? I dunno, so I made sure because of the price to buy a couple extras.
