smarsh102
Topic: Which Hitch? Posted: 19 Feb 2012 at 4:24pm |
Originally posted by David
Welcome to the group smarsh102! Thaank you for your comment. Please feel free to make plenty of comments , ask questions, tell stories,...whatever!  |
Thanks David. I am a long time lurker, well 1 season and the research before I bought.. I am hoping to add some information once in a while.
Guests
Posted: 19 Feb 2012 at 7:29am |
smarsh102
Posted: 19 Feb 2012 at 12:37am |
I use the Reese 350 Mini WD to tow our 172 behind a Chrysler Pacifica. I am very happy with the set up and although I don't have a lot of experience towing I am very comfortable towing the pod around and have not experienced any kind of sway.
This option was considerably cheaper than the Equalizer hitch.
http://reeseprod.com/content/products.aspx?lvl=3&parentid=1600&catID=1605&part=66024
dsmiths
Posted: 31 Jan 2012 at 9:16pm |
I have pulled local short trips without antisway (friction clamp type ) but on the interstate and in windy conditions and when those 80 thousand pound 80 mph beheamouths pass you, I think the anti sway makes a difference, I have tried both, I dont feel the equalization cinch chain type is needed for the light weight R Pod, but I have never towed out west in the flat lands with 40mph cross winds.
Dane and Donna Smith
2011 RP-172
lift kit
rid415
Posted: 30 Jan 2012 at 6:51pm |
i was told by my dealer and and forest river that wd and or sway bar that this stuff wasnt required and not recomended for all r-pods and driving back from calgary it wasnt an issue. pod pulled fine and did not sway at all.
Bill-GA
Posted: 29 Jan 2012 at 9:44pm |
I picked up a new 2 inch ball rated at 6000 lbs (shaft was larger than what I had - rated at 3500 lbs) and installed it with my adapter for a fiction anti-sway attachment. I didn't think I really need an anti-sway bar until I read about being passed by trucks that push air sideways as they pass and cause sideways oscillation. It sounds very plausible, but I haven't taken a long trip yet and experienced this real time. But I WILL install the friction sway bar when I travel.
Bill & Bev
13 yr old dachshund 'Elsa'
2011 Toyota Tundra 2WD TV
Tidalwave4455
Posted: 28 Jan 2012 at 9:16am |
I have the Equalizer E2 (600 lbs) WDH with friction sway bars. I tow with a Chevy Silverado PU (with tow-haul). I almost have to remind myself that I am towing the Pod even in high cross winds. There is essentially no porpoising of the Pod (Nothing flies out of the cabinets). It might be 'belt with suspenders', but I like the peace of mind. I have seen a minivan with five people towing a 171 Pod with just a regular hitch. I just shook my head in disbelief. They must be going in first gear whenever they went up a hill.
Bill-GA
Posted: 28 Jan 2012 at 9:15am |
Originally posted by Footslogger03
Yeah Bill ...the difference is in the diameter of the shaft under the ball. If you get 2" ball with the thicker shaft it will have the higher rating.
MJ |
Thanks. I'm off to the store!
Bill & Bev
Footslogger03
Posted: 28 Jan 2012 at 12:10am |
MJ
Livin' the Dream ...'Slogger
Bill-GA
Posted: 28 Jan 2012 at 12:05am |
My '10 177T RPOD is in the area of 2700 lbs.... Unloaded. With a full load of water and equip. I could see me going over 3500 lbs. My factory installed receiver is rated over 5000 lbs. But I just noticed that the 2 inch ball I put on the hitch says its rated at only 3500 lbs. I'm new to heavy trailering .... Is there a 5000 lb. rated 2 inch ball? ... Or another solution?
Bill-GA
Bill & Bev
