  New Posts New Posts RSS Feed: TV DVD Radio problems
Topic ClosedTV DVD Radio problems
Direct Link To This Post Topic: TV DVD Radio problems
    Posted: 30 Oct 2011 at 8:13pm
Make sure the antenna amplifier is on, look for a small button where the TV antenna is plugged into the pod.
melp View Drop Down
Direct Link To This Post Posted: 31 Oct 2011 at 12:37pm
Thanks for the info HOWEVER the signal amp is on when this occurs.
melp
Direct Link To This Post Posted: 31 Oct 2011 at 5:34pm
Welcome to the group! Smile  Sorry about the issue.  Does it do it even in areas where reception is very good?
melp View Drop Down
Direct Link To This Post Posted: 31 Oct 2011 at 5:45pm
yes
melp
CubFanMan1 View Drop Down
Direct Link To This Post Posted: 31 Oct 2011 at 10:29pm
For all those that are having poor TV reception, have you tried rotating the antenna?
Believe it or not you can rotate the antenna on top of the unit, although you need a ladder to reach it on the roof.
tpierce220 View Drop Down
Direct Link To This Post Posted: 01 Nov 2011 at 8:51am
How easy is it to rotate the antenna?  We were only to get one channel sort of this year and even that was very spotty even though we were in a town with several television stations (Springfield, IL).
melp View Drop Down
Direct Link To This Post Posted: 01 Nov 2011 at 9:19am
Cannot rotate antenna. Unidirectional, this is a 2011 model year.
melp
Direct Link To This Post Posted: 01 Nov 2011 at 1:04pm
My 2010 is fixed, too.
this_is_nascar View Drop Down
Direct Link To This Post Posted: 01 Nov 2011 at 2:49pm
Never heard of a moveable antenna on an R-Pod.  You sure your antenna isn't broken if it's moving?
"Ray & Connie"
- 2017 R-Pod RP-180
Direct Link To This Post Posted: 01 Nov 2011 at 4:54pm
Does anyone have problems with reception . I have replaced the audiovox TV with a 19" Samgun flat screen.   With both TV's when I walk in the trailer the recection breaks up. Anyone having that problem??
Well..........here's my take on the antenna
Though I'm sure to draw the ire of Podders everywhere, I have to say I was not overly impressed with the performance of the TV antenna on the Pod. We ham radio operators have a "tongue in cheek" saying: Omni-directional antennas work equally poorly in all directions! LOL  Given that, I wouldn't expect great performance from what I referrred to as the "Frisbee antenna".  It is mounted even lower than the A/C unit, so that doesn't help matters either.
Also, when we went to digital TV, the situation changed - especially when on the fringe of reception.  In the old days of analog TV, we might get a "snowy" picture, but could watch and hear most of what was going on.
When on the fringe with digital, if the TV misses or misreads a bit or two of data (CODEC) the TV doesn't know what to do about that.  So, the picture freezes/becomes pixelated/no or broken sound, etc.  If it misses a lot of data, is just can't decode the signal at all - it will just sit there and say something like "no signal found", or something to that effect.  It may be receiving random bits of data, but it just thinks it is "so much hooey" and can't do anything with it.
IMHO, digital is great when a strong signal is present.  Analog was better under less than optimal conditions.  I doubt there is a malfunction with your antenna.  It is probably doing the best it can.
If I were still in my Pod, I would likely have something on an extendable pole - in much the same manner as I do my ham antenna now.  While not a huge TV watcher when camping, I do like the Indy car races and, to a lesser degree, Nascar.  Being able to catch the local weather/radar comes in real handy also.  If TV is important, you may want to consider options other than the OEM antenna.  Again, IMHO.
