  New Posts New Posts RSS Feed: Ground Clearance??
Topic ClosedGround Clearance??
 Post Reply Post Reply Page  <1 3456>
secretbard View Drop Down
Direct Link To This Post Topic: Ground Clearance??
    Posted: 26 Jun 2011 at 12:29am
Ground clearance also depends on how low to the ground your hitch is.  I've seen some really low hitches on some vans and SUVs where the tong jack scrapped the ground over every bump.  I haven't seen a problem with my Trailblazer.  Honestly, my gravel driveway isn't at all level and has some nice dips and bumps in it and I've never scraped either the tong jack or the stabilizers.  Some of you guys must be really low to the ground.  My honest, but newbie advice would be to drive around with it for a while and see if the risers become necessary.  This is not to say you shouldn't get the riser, for multiple other reasons, but I don't see it in my foreseeable future.  I'm sure that I may scrape the tongue jack or stabilizers at some point while roughing it in some campgrounds, but as long as it's grass and dirt, I'm not too worried about it.
2010 Rpod 172   :)
2004 Chevy Trailblazer
jayber View Drop Down
Direct Link To This Post Posted: 25 Jun 2011 at 6:30am
Day one I ripped off a stabilizer jack pulling into our driveway, considering the sewer pipe is the next lowest point, the risers were a necessity for me.  For $75 they are well worth it if for nothing more than piece of mind.
Jay
2010 Honda Odyssey
RP 171 aka PodInn
Direct Link To This Post Posted: 25 Jun 2011 at 12:17am
I have the same jack as ToddsPod (same jack stands too).  I've removed the factory jack, especially before I got risers and a weight distribution hitch that thing hit the ground every time I sneezed.  A real pucker factor when you are doing 60!
Podsible Dream View Drop Down
Direct Link To This Post Posted: 24 Jun 2011 at 11:24am
Actually it is a dolly designed to move trailers with a ball hitch. You can get them from Overton's online(where I got mine - I looked for the largest wheels for easiest movement), Harbor Freight, probably Northern Tool - they are apparently most often used to move boat trailers. They run $50 to $120.
Chris and Walt
'10 RP-171 'Free Spirit'
Riverdog View Drop Down
Direct Link To This Post Posted: 24 Jun 2011 at 11:19am
Is that a regular 2 wheel dolly like you would move a fridge with?
Direct Link To This Post Posted: 24 Jun 2011 at 11:12am
I have a long gravel driveway with humps and bumps (read not the kind you back into). I splurged and got a two wheel dolly. It's a little bigger than a wheeled jack, but has 10" balloon tires and is easy to maneuver. My wife and I can move the pod around easily on the gravel.
Chris and Walt
ToddsPod View Drop Down
Direct Link To This Post Posted: 24 Jun 2011 at 11:04am
I have a swing down wheel jack mounted on the side of the tongue. I got it at harbor freight for $20. Easy to mount and with a little effort you can push it around. Although I don't much because of the sloped drivewayOuch.
On the topic of risers, I look forward to getting a pair and installing them. The biggest issue is, as stated above, the sloped driveway. If I don't pull in and out slowly and carefully and at just the right angle I grind the stabilizers on the driveway.
'07 Dodge RAM 1500 ST Longbed QuadCab 4.7L V8 --- '10 Forest River R-Pod 172
Direct Link To This Post Posted: 24 Jun 2011 at 10:43am
Thanks for the great replys! I'm glad to see I'm not alone in my thinking. We are taking her out to a national forest campsite tonight and we'll see how it goes. I am going to order the risers, though.
Another question: Do most folks have a wheel for their tongue jack? I'm thinking my hulking teenage boys and I could manhandle it if it did.
Direct Link To This Post Posted: 24 Jun 2011 at 7:02am
I'm sure if you talked to a design person about the aesthetics of the lovely R-Pod there would be a rational explanation for the lower deckbheight. It would probably involve the appearance bas on the width to height ratio, the weight to track width, the wheel and tire size (why put 17"wheels on a 2000 lb trailer?),not to mention the lovely curvature of the exterior and all the stuff set on the roof.
I agree with everyone here. Those risers make a great difference in drivability and, to my eye, into appearance as it sits on the ground, as well as using the entry stairs.
Enjoy your new Pod!
Chris and Walt
Direct Link To This Post Posted: 23 Jun 2011 at 9:58pm
Welcome.  I went 1 1/2 camping seasons w/o the risers and I'm very glad to have them now.  I've found the steps are easier with the risers because it makes each step the same height (the first step up was lower before).  Its easier to dump the tanks as harleyguy said, and I can now move it around my driveway and yard w/o scraping the steps like I used to.
