  New Posts New Posts RSS Feed: Fridge Problem
Fridge Problem
Post Options Post Options   Quote StephenH Quote  Post ReplyReply Direct Link To This Post Topic: Fridge Problem
    Posted: 20 Jul 2026 at 9:51am
I found that the regulator was okay. The issue was that there was an oily fluid in the gas line leading to the refrigerator. Turn off the propane at the bottle. Then disconnect the hose from the refrigerator end and the regulator end (not the pigtail, but the end that supplies the appliances). Put the regulator end in a container. Using a compressor, blow air in from the refrigerator end. If I am right, a significant amount of thick, oily liquid will be in the container. Then reconnect the lines at both ends and after the air is purged, try the refrigerator again. If it works, then this was the issue.
The reason this works is that the stove, furnace, and water heater take a high volume of propane. The flow is enough to push through the liquid for the high-volume appliances. The low flow for the refrigerator does not have the volume to push the liquid aside.
hogone View Drop Down
Post Options Post Options   Quote hogone Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2026 at 7:28am
Not gonna be much help here, but had the exact same issue when I had my pod.  Did everything that was recommended at the time; cleaned rods, changed regulator (even though all other gas stuff worked great), blew out lines, replaced thermocoupling (I guess that's what its called), cleaned combustion area, etc.  Spent about $200 on parts and I never got it working and just gave up.  It was a bummer as those fridges really need gas if boondocking and traveling for periods of time.  If you ever get it running, Ill be anxious to hear just to see where I failedUnhappy .  Jon
Jon & Pam
2025 GD 17MKE
2013 RP177(sold Nov 25)
2023 F150
CHEESEHEAD
gpokluda View Drop Down
Post Options Post Options   Quote gpokluda Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2026 at 7:08am
If what jato recommends doesn't work, test your stove and furnace. If they experience any fluctuations in flame or ignition, you regulator may be the issue.
Gpokluda
2017 Rpod 179(sold 2023)
2022 Escape 5.0TA
2022 Ford F150 4X4 3.5EB
Honda SCL500
Post Options Post Options   Quote jato Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2026 at 1:51am
Carefully clean the two contact rods above the combustion area.  Also a partially plugged propane regulator may be at fault.
2BOverlanding View Drop Down
Post Options Post Options   Quote 2BOverlanding Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jul 2026 at 4:06pm
I have a 177 with a Dometic RM8501 3 Way fridge.  I runs on 12 volt and shore power but it will not run on Propane.  I have replaced the Thermocoupling and the Grey control box on the back of the fridge.  The pilot light will come on and it will burn for a short period and then will go out.
Not sure what to check or do next.
Could a faulty gas valve creat this issue? Is it the main board on the front of the fridge?
