  New Posts New Posts RSS Feed: The cabin jumps out of frame
Lonetraveler View Drop Down
Post Options Post Options   Quote Lonetraveler Quote  Post ReplyReply Direct Link To This Post Topic: The cabin jumps out of frame
    Posted: 17 Mar 2026 at 9:04am
My 171 is a 2013 model. I bought it 7 months ago. I don't know how to describe this issue but here goes. As I drove it on a trip the two up front sides jumped out of the exterior one inch framing. So I removed that one inch right angle framing and replaced it front to back on both sides with two inch steel right angle framing. I thought I solved the problem but it did not. It seems the cabin jumps up while I am driving (or going over bumps) and  moves out of the side 2 inch framing. Consequently the door is no longer aligned and I have to push the front of the cabin back into position.  Can someone please help me find the solution to this problem.  Thanks.  Lonetraveler
hole in one
Post Options Post Options   Quote GlueGuy Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2026 at 10:45am
Can you post a picture or two?
Post Options Post Options   Quote Lonetraveler Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2026 at 11:24am
Yes, I can post a picture and will do so as soon as I get home. Thanks
Well, I could post a picture if I can figure out how to do that. I am still searching to find the 'add' button. Can someone help me?  I am old and new to this site. Thanks
Edited by Lonetraveler - 17 Mar 2026 at 12:05pm
hole in one
Post Options Post Options   Quote Lonetraveler Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2026 at 12:10pm
I think I found out how to upload a picture
hole in one
gpokluda View Drop Down
Post Options Post Options   Quote gpokluda Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2026 at 7:05am
Hi Lonetraveler,  sorry to hear you are having this issue. This is a serious issue with no easy fix. The fact that the sides/body of the camper are moving around on the floor, points to wall separation at the joints, probably due to water intrusion causing the wall to degrade and the fasteners to break free. Basically the walls have to be rejoined to the front and the floor. Having an RV repair shop do that is probably best, but it is going to be costly, probably challenging the value of your rig.
Gpokluda
2017 Rpod 179(sold 2023)
2022 Escape 5.0TA
2022 Ford F150 4X4 3.5EB
Honda SCL500
Post Options Post Options   Quote David and Danette Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2026 at 7:25am
 There are factory videos of the r-pods being built perhaps if you could find one you could get a better understanding of how they are built and what your problem is. But I agree with what has been said that it appears to be water damage to the floor and could be expensive to fix. The wood floor is attached to the frame with metal fasteners if the wood gets wet and rots the fasteners will break free from the floor allowing the body of the camper to shift from being attached to the frame. Sorry for your problem but when it comes to wood water will often cause a lot of damage.
2023 Aliner Scout Lite
Post Options Post Options   Quote Lonetraveler Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2026 at 9:36am
Thank you. I guess I will take a look at the floor and see if this old man can resolve the problem. It was so nice you gave me the bad news, but at least now I know what needs to happen.
hole in one
Post Options Post Options   Quote gpokluda Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2026 at 2:40pm
There are probably a number of non-elegant ways to deal with it.  It all depends on what you're tolerance is for how good it looks in the end.
Gpokluda
2022 Escape 5.0TA
Honda SCL500
Post Options Post Options   Quote Lonetraveler Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2026 at 5:08am
since I am a lonetraveler and only travel for 4 to 6 days 7 times a year, how it looks is secondary to safety. I certainly can't sell it without disclosing the issue. So my intentions are to take up the linolem and check the flooring. If the entire flooring needs to be removed and replaced...well I will think about it. If only the front section of the floor has rottened out I will figure a way to repair it. Regarding the exterior if I think it a good idea to put up side metal braces to keep the cabin centered, I know a good welder. In any case...this old retired guy has just found another thing to keep him busy. If anyone has resolved such a problem and has ideas, please share them with me. I don't mind being a copy cat!
hole in one
Post Options Post Options   Quote GlueGuy Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2026 at 12:52pm
The major part of the problem is that the floor and the linoleum go wall-to-wall. So to replace either, you really need to lift the entire chassis from the frame/floor. Plumbing and some electrical go through in a few spots.
It's a really (REALLY) big job.
Edited by GlueGuy - 19 Mar 2026 at 12:52pm
