  New Posts New Posts RSS Feed: tank drain hose storage
tank drain hose storage - Event Date: 08 Jan 2025
JD R-Pod 197 View Drop Down
Post Options Post Options   Quote JD R-Pod 197 Quote  Post ReplyReply Direct Link To This Post Calendar Event: tank drain hose storage
    Posted: 08 Jan 2025 at 10:38pm
Hi all,  I've searched the forum for info on this and haven't seen anything on it. If I'm the first then I'm even more angry! So, I'm Creating a new topic.
Regarding my problem:
I bought a 2025 RP197 a week ago. It's my first RP. During my inspection I casually commented on the removable caps for the storage of the tank drain hose within the rear bumper pipe with no feedback from the dealer. After getting the unit home and trying to insert my RhinoFlex Hose that I have used for years in my Forest River Willdcat Maxx trailer, It would NOT FIT into the rear bumper. The inside diameter of the bumper is less than 4 inches. The twist-locking tabs on the fittings are too thick to slide in. Is this a new problem with the 2025 RP or is everyone already just so over complaining to Forest River about it they have given up?
Post Options Post Options   Quote GlueGuy Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2025 at 11:04am
Back in the day of our RP179, there was this tiny storage tube. We replaced it with one big enough to hold our RhinoFlex hose.
It might be better if they didn't supply anything in the first place.
Post Options Post Options   Quote jato Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2025 at 12:33pm
Agree with G.G above.  Purchased a 177 back in January 2011 and the storage tube was of sufficient size to hold our RhinoFlex hose.  Unfortunately on our last 30 day trip out west last September, someone had a great need to "borrow ours" (both the storage tube and the RhinoFlex hose) and not return it!  So, after an almost 14 year stint, we had to purchase new for both.
Edited by jato - 14 Mar 2026 at 4:28pm
gpokluda View Drop Down
Post Options Post Options   Quote gpokluda Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2025 at 5:50pm
+1 the storage tube that came with our 179 was a joke. I mounted a full length tube to the back that would easily accommodate the added size of the heavy duty tubes.
Gpokluda
2017 Rpod 179(sold 2023)
2022 Escape 5.0TA
2022 Ford F150 4X4 3.5EB
Honda SCL500
SeasTheDay View Drop Down
Post Options Post Options   Quote SeasTheDay Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2026 at 7:14pm
I am so sorry to hear this happened to you! We just purchased our 2025 197 2 weeks ago and because of your post now know that our rhino tube will not fit which make me absolutely furious. Spending that amount of money they should atleast fix the problem for us. Or do it right the first time.
Post Options Post Options   Quote gpokluda Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2026 at 9:03am
It seems Forest River believes Rpods are for light duty use and assumes most folks will go with the light duty slinky hoses.
Gpokluda
2022 Escape 5.0TA
Honda SCL500
Post Options Post Options   Quote GlueGuy Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2026 at 7:47pm
I wouldn't call it "light duty". It is simply too short to be of much use.
