  New Posts New Posts RSS Feed: Awning Fever
Awning Fever
Post Options Post Options   Quote David and Danette Quote  Post ReplyReply Direct Link To This Post Topic: Awning Fever
    Posted: 17 Sep 2025 at 5:28pm
  I think the biggest stress would not be from the weight of the awning but the wind hitting the awning when opened up. I am a sailor and there is a lot of pull on even a small sail. And should never have a awning extended during a windy day or storm.
2023 Aliner Scout Lite
gpokluda View Drop Down
Post Options Post Options   Quote gpokluda Quote  Post ReplyReply Direct Link To This Post Posted: 18 Sep 2025 at 12:11pm
+1 on the wind loading. More of a worry than the weight of the awning itself for me.
Gpokluda
2017 Rpod 179(sold 2023)
2022 Escape 5.0TA
2022 Ford F150 4X4 3.5EB
Honda SCL500
poohbill View Drop Down
Post Options Post Options   Quote poohbill Quote  Post ReplyReply Direct Link To This Post Posted: 18 Sep 2025 at 10:00pm
Reading through, I’m struck by how little is made of the keder rail that model year had, equipped from the factory. It is how the R-Dome is attached and used by many to attach awnings. There were a number of ytubers posting afterwards how to make and install one.
2016 179 Gastropod
2017 Ridgeline
Yerfdog1 View Drop Down
Post Options Post Options   Quote Yerfdog1 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2026 at 7:47am
I just bought a 2017 rpod 179 which had a factory Thule awning which had been torn off in a storm. The c channel (keder rail) is still mounted on the camper. I wanted to just replace it with a new Thule but they have pulled out of the US market. I have called Forest River and everyone else trying to see if I could mount something to the existing rail. Not sure what to do because it’s a proprietary rail. I want a retractable box awning like what was on originally. Does anyone have any ideas on what I can do here?
JR View Drop Down
Post Options Post Options   Quote JR Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2026 at 8:48am
We purchased a new 2019 / 179 in July of 2018.  It was my understanding then that the trailers from the factory came with either a "Keder" rail for the Rdome application or a Thule awning.  If the purchaser wanted a Thule awning it would have to be manufactured that way in the building process because there was more supports built into the area where the awning attaches to the trailer.  If the trailer was built for the awning application then the "Keder" rail was not installed on the trailer.  Which I can attest to because my 179 does not have a Keder rail but we have a Thule awning.  My guess is that your trailer was not producted for the awning application and had a Keder rail installed a the time of production.  Sometime after the trailer was delivered to the dealer the Thule awning was added to the unit either by dealer or owner.  Which explains why the Thule awning is no longer there.  In answer to your question of if there are many applications that can use the Keder rail for attaching an awning to your unit.  Some will be manufactured for that application or you can make up your own version of an awning using the existing Keder rail.  For ideas search this forum for old posts there is a lot of ideas and information out there.  I would not suggest trying to re-install another Thule awning or something similar to that.  The trailer just does not have enough "beef" in the walls to attach an awning too.  Hope this helps.
Jay
179/2019
Post Options Post Options   Quote Yerfdog1 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2026 at 11:01am
Post Options Post Options   Quote GlueGuy Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2026 at 11:09am
The 2017 Rpods did NOT have the reinforcement for an awning. If yours had the awning, it was added after manufacture by a dealer or owner.
Our 2017 RP179 does not have the awning reinforcement. It was not an option back then.
JR View Drop Down
Post Options Post Options   Quote JR Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2026 at 11:15am
I didn't know that, thanks for the clarity. Jay
Jay
179/2019
