  New Posts New Posts RSS Feed: 25-194 Antifreeze Hose ?
carlmoore View Drop Down
Post Options Post Options   Quote carlmoore Quote  Post ReplyReply Direct Link To This Post Topic: 25-194 Antifreeze Hose ?
    Posted: 10 Nov 2025 at 4:39pm
Hello, Podders - I am trying to get antifreeze into the system - I see a less than helpful sticker in the cargo area next to the water intake the says to bypass and hook up - bit WHERE is the hose location to drop in the antifreeze jug??? What am I missing?
THX!
Pete Brayton View Drop Down
Post Options Post Options   Quote Pete Brayton Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2025 at 10:27pm
There is possibly a panel that you have to remove in the cargo area next to the water intake. Probably the panel with the sticker is. Good luck!
2021 Rpod 196
2013 Ford 150 V8
JR View Drop Down
Post Options Post Options   Quote JR Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2025 at 8:51am
Keeping in mind that you want to find and turn the valves to "bypass" the water heater prior to running the antifreeze into the fresh water lines.  Also draining the water heater is important and you can check the status of the anode rod for possible replacement.  Hope this helps
Jay
179/2019
Post Options Post Options   Quote jato Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2025 at 5:26pm
Go to the cargo area of your 194 (on the slide side).  Locate the access panel.  It may be secured by screws or velcro.  Remove panel to expose the water pump and connected plumbing.  You should see a 3-way adapter or valve near the water pump.  One line will be short and open on the end, this is your pickup hose.  Turn the bypass valve to select the antifreeze port instead of the fresh water port.  Insert the pickup hose into the antifreeze jug and begin the winterization process.
