  New Posts New Posts RSS Feed: New Member - solar trickle charger question
BlackeShepe View Drop Down
Post Options Post Options   Quote BlackeShepe Quote  Post ReplyReply Direct Link To This Post Topic: New Member - solar trickle charger question
    Posted: 15 Apr 2025 at 9:42am
Hello there,
I'm a new owner of a used (2024) 171C
I'm thinking I should use a solar trickle charger to keep the battery up when I'm not on shore power and it's just waiting for our next adventure...
Does anyone use something like this?
My driveway spot where I keep it, it would be in the shade of the Pod but it's plenty bright enough to keep a charge on it as long as we're not running the lights all the time.
(We use similar ones to keep the charge on our maintenance vehicles when they aren't used daily)
Edited by BlackeShepe - 16 Apr 2025 at 9:16am
Bill and Tina J
2024 R-171C, 2018 Chevy Silverado 1500
Somewhere in (hot) California
30 miles from Hell, CA (Google it)
Been a long time since we trailer camped.
Post Options Post Options   Quote GlueGuy Quote  Post ReplyReply Direct Link To This Post Posted: 15 Apr 2025 at 11:26am
Not knowing how much shade you're talking about, and knowing how many watts your solar charger might put out, it's difficult to hazard a guess about how well it might do.
That said, trickle charging a battery that does not have much load seems like a light lift. You might consider putting the panels on the rood of the Rpod to eliminate the shade issue.
How far are you from Blythe?
gpokluda View Drop Down
Post Options Post Options   Quote gpokluda Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2025 at 8:56am
We used a portable 130watt panel to keep our Rpod battery charged. We skipped using the Zamp port and just wired the fused pigtail that came with our panel directly to the battery. We also installed a battery cutoff so there would be no parasitic drain from any electronics in the camper. You could probably get by with a basic 100watt panel, just make sure it is secured from wind or theft.
Gpokluda
2017 Rpod 179(sold 2023)
2022 Escape 5.0TA
2022 Ford F150 4X4 3.5EB
Honda SCL500
Post Options Post Options   Quote jato Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2025 at 9:32am
Another option is to simply unhook the ground (-) cable from the battery when not in use.  This is what I have done for the past 14 years with our 177.
Post Options Post Options   Quote StephenH Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2025 at 1:15pm
