  New Posts New Posts RSS Feed: Floor/sidewall repair
Post Options Post Options   Quote GlueGuy Quote  Post ReplyReply Direct Link To This Post Topic: Floor/sidewall repair
    Posted: 03 Apr 2025 at 10:44am
I use a tool called Paint.net
Very easy to use, and easy to learn.
JShimp View Drop Down
Post Options Post Options   Quote JShimp Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2025 at 11:07am
I like it.  Still could not figure out how to just downsize though.  What am I missing?
JRS
Post Options Post Options   Quote StephenH Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2025 at 2:02pm
In which program? If it is the GIMP, load your picture. Select "Image" on the menu bar. On the drop-down menu, select "Scale Image" and use the dialog to adjust the size. When you finish, the image will be downsized. Then all you need to do is export it to either a .jpg or .png image for use on the forum.
Post Options Post Options   Quote GlueGuy Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2025 at 10:34am
If you're in paint.net
Select the menu item Image->Resize
Then you can select a percentage or pixel size.
Post Options Post Options   Quote JShimp Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2025 at 7:10pm
Got the floor all repaired and put down carpet tiles.  The slideout operates without all the straining noises and dragging the floor like it did.  Still trying to downsize pictures with print.net....I am not too savvy, I guess.  Thanks.
JRS
Post Options Post Options   Quote StephenH Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2025 at 10:13pm
Thanks for the update. I 'm glad you were able to fix it.
truthseeker61 View Drop Down
Post Options Post Options   Quote truthseeker61 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2025 at 9:02am
Sure would like to see your pics.
larryfee9 View Drop Down
Post Options Post Options   Quote larryfee9 Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2025 at 7:06am
New owner from Canada (well not new per say, 2014 176, in overall great shape).
That being said, I would be interested to see some pics of this outrigger fix as I may have same issue.
Going to dig in a bit but links would help
appreciated.
LF
Post Options Post Options   Quote JShimp Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2025 at 7:14am
Will try again to post some pictures.  It was not a terribly hard fix, thanks to my friend who made the brackets.  The slideout works properly now (without dragging) and leakage seems to be gone.
JRS
Post Options Post Options   Quote larryfee9 Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2025 at 7:21am
Thanks
I actually found John M's own website after asking this:
this is a very detailed option, will take a peak under mine
Thanks again
LF
