171 Inverter Prep |
gpokluda
Joined: 11 Nov 2018 Location: East Idaho Online Status: Offline Posts: 431 |
Topic: 171 Inverter PrepPosted: 16 Mar 2025 at 10:41am |
That’s what I did when I installed an inverter in our 179. To keep the wires as short as possible. I drilled through the front to connect to the batteries. I sealed the penetrations liberally. The problem I ran into was battery capacity. For a 2000watt-3000watt you are going to need 200ahr battery capacity at the very least. There are some very experienced boondockers on another forum I’m on that say 400ahr is the minimum for a 3000watt inverter. The only way I could achieve that on our 179 was a lithium battery bank in the front storage area. So my wife and I opted to get a camper more suited to our needs. |
Gpokluda
2017 Rpod 179(sold 2023) 2022 Escape 5.0TA 2022 Ford F150 4X4 3.5EB Honda SCL500 |
Dragon Pilot
Joined: 08 Oct 2013 Location: Seattle, WA Online Status: Offline Posts: 2 |
Posted: 14 Mar 2025 at 5:31pm |
I have a 178. The forward storage bin is the most practical space to put in, say, a 2000-3000 watt inverter, and get it close to the battery. It's a fairly tight space to work in. And the wires to the battery would probably have to go through a hole in the floor (I hate drilling into flooring). the hole would have to be sealed really good after the wires are run through to the battery.
RP-178, 1997 Explorer 5.0 V8 AWD
wmsnyderphoto
Joined: 01 Feb 2025 Online Status: Offline Posts: 5 |
Posted: 27 Feb 2025 at 8:59am |
Thanks.
Rpod-Couple
Joined: 21 Jun 2021 Online Status: Offline Posts: 55 |
Posted: 26 Feb 2025 at 8:49pm |
The River Forest 2025 Rpod 171 interior pictures show “Inverter Prep” label on the dinette seat adjacent to the sink. There are screws holding the plywood seat in place. Remove the screws and lift up the plywood and I believe you will find the inverter wiring. (I wouldn’t put the screws back in to make it easy to get to the water pump, heater and inverter.)
Steve & Elaine
2021 R-pod 2023 VW Atlas Cross Sport |
Rpod-Couple
Posted: 26 Feb 2025 at 8:41pm |
I have a 2021 R-pod 171. I suspect the inverter prep is under the dinette seat on the drivers/sink side. Pretty sizable space and it’s close to the battery, and battery cutoff switch.
Steve & Elaine
wmsnyderphoto
Posted: 26 Feb 2025 at 11:39am |
I know what the inverter does. I have seen other units where inverter prep meant they had an unterminated 120V wire at some location that you could hook to inverter to run the outlets and then just needed to add inverter and hook to battery.
Edited by wmsnyderphoto - 26 Feb 2025 at 11:48am |
gpokluda
Posted: 26 Feb 2025 at 7:30am |
As a rule, inverters are placed as close to the battery(s) as possible. Usually within 1-2ft. I believe StephenH is right. It probably means there are simply 12v leads located where you can install an inverter.
Gpokluda
Posted: 26 Feb 2025 at 1:07am |
But not if it is "inverter prep." That just means that 12v wiring is placed somewhere with a suitable space to hold an inverter., not that an inverter is actually there. Your dealer should be able to explain that "feature" to you and to advise on suitable inverters. The "Inverter Prep" may also include the connections to be able to feed the 120v outlets if an inverter is installed, but I can't say for sure if that is the case.
Joined: 14 Jan 2013 Location: Near Nashville Online Status: Offline Posts: 1455 |
Posted: 25 Feb 2025 at 9:57pm |
Not sure what's meant by "inverter prep", but an inverter changes, DC to AC, so you should be able to plug any AC device or appliance you want into it, within wattage limits. TT
FJ Cruiser |
wmsnyderphoto
Posted: 25 Feb 2025 at 11:33am |
My new 171 says it has inverter prep but I have yet to find the 120V wire that would connect to the inverter. Anyone know where this would be located?
