  New Posts New Posts RSS Feed: Batteries
Batteries
mjlrpod View Drop Down
Post Options Post Options   Quote mjlrpod Quote  Post ReplyReply Direct Link To This Post Topic: Batteries
    Posted: 15 Sep 2024 at 12:22pm
My solar system now is made up of two 100ah Lifepo4 batteries, two 230 watt solar panels, along with all the needed supporting equip. My batteries are Renogy bluetooth self warming. I do not keep the camper plugged in when stored at home, and my batteries stay topped off, even with the 12v fridge running. I will NOT be running anything in the winter time, except the normal parasitic drain of car mon detect etc. Should the batteries be removed? I'm in new england and 20 degree days are plentiful, and sub zero temps in january - february.
Edited by mjlrpod - 15 Sep 2024 at 12:44pm
2020 R-pod 195
2015 Frontier sv 4.0L 6cyl
I'll be rpodding
Post Options Post Options   Quote GlueGuy Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2024 at 1:58pm
LFP batteries are theoretically OK to use down to -4F, however there are issues charging them in low temps. Whatever you're using to charge them should account for the low temp, and reduce the charge current accordingly.
Post Options Post Options   Quote StephenH Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2024 at 3:36pm
You did not say specifically which battery model you purchased. I looked up and if it is the RBT12100LFP-BT-US, then you are good to go. The batteries will turn themselves off if the temperature gets too low. If you have solar connected, then the batteries will warm themselves until they get warm enough to operate. Pretty nifty. As long as you have sunlight, it will work. However, if you cover the trailer or have extended cloudy weather, then it is likely best to disconnect the batteries.I mention the specific model, because not all the models have the self-heating function.
gpokluda View Drop Down
Post Options Post Options   Quote gpokluda Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2024 at 4:24pm
I am assuming you are speaking of the rp195? For the life of me I don't know where you could cram that much solar on a 195 Smile
I have a similar setup on my current camper; a littler more solar and a little more battery capacity, but in theory it works the same. Like StephenH said, if your batteries have a thermal shut-off, you will be fine. If they do not have a thermal shut-off, follow GlueGuy's advice.
Gpokluda
2017 Rpod 179(sold 2023)
2022 Escape 5.0TA
2022 Ford F150 4X4 3.5EB
Honda SCL500
ppine View Drop Down
Post Options Post Options   Quote ppine Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2025 at 10:51am
Lithium batteries do not like the cold.
They are best stored above 14 degrees F.
Take them in the garage in the winter.
Forester
2022 Ram diesel
2019 Nash 26N
2015 rpod 177
