  New Posts New Posts RSS Feed: Refigerator & outlet woes
Jenga Jack View Drop Down
Post Options Post Options   Quote Jenga Jack Quote  Post ReplyReply Direct Link To This Post Topic: Refigerator & outlet woes
    Posted: 27 Jul 2024 at 2:24pm
We had been camping for 3 days hooked up to shore power. Everything was working fine. After reaching for a cold one and closing the door, the refrigerator status bar lit up with the “electrical plug” light and the “fault” light blinking, and a beeping signal. I opened and closed the door a few times to no effect. Turned the breaker off/on, turned the shore power box off/on, no effect. Couldn’t solve it so switched to LP and refrigerator worked fine. (also tested on the battery mode, it worked fine)
Later noticed that none of the four electrical outlets worked. When removing the fuses one by one, none were blown, but on 3 of them a red light lit up on the circuit board next to the pulled fuse. (fuses #2, 3, 6)
I have limited knowledge of electrical systems, so before I take the rig to a service center, any advice or things to try/test would be helpful.
Attached are various photos; and below are some specs.
2014 Forest River R-Pod #178 Hood River edition
Dometic refrigerator model RM 8501
WFCO electrical box, model WF-8955PEC
2014 R-Pod 178 aka the "Kobra Pod"
following a 2015 4Runner wherever it may wander
Winterpod View Drop Down
Post Options Post Options   Quote Winterpod Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jul 2024 at 6:37pm
Check the GFI OUTLET
Winter pod
2013 R-Pod 178
2007 Silverato 1500 LT.
Trek Stash 8 29er hard tail
Old Town Kayak
Rpod-Couple View Drop Down
Post Options Post Options   Quote Rpod-Couple Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jul 2024 at 7:30pm
I agree with checking the GFI outlet to see if the GFI tripped. But it may also be a problem with the wire to the GFI outlet. My R-Pod 171 brand new had a loose wire at the GFI. That would cause all the other downstream outlets and fridge AC power to be off.
Steve & Elaine
2021 R-pod
2023 VW Atlas Cross Sport
Post Options Post Options   Quote Jenga Jack Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jul 2024 at 9:20pm
I am an idiot!!!
Per the posted responses from "winter pod" and "Rpod-Couplr" I located the GFCI outlet near the floor next to the refrigerator, pressed the reset, and refrigerator is working again.
My head is down with my tail between my legs. Ouch
Once again the forum comes through. Thank you all!
Pod People View Drop Down
Post Options Post Options   Quote Pod People Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2024 at 10:45am
Mistakes are learning tools.
The only people who don't make mistakes are people that do nothing.
you are not an idiot-just another rv owner learning about their rig
Vann
Vann & Laura 2015 RPod 179
Post Options Post Options   Quote StephenH Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jul 2024 at 7:32am
+1
Been there, done that.
