  New Posts New Posts RSS Feed: How to clean silicone sealant
Geezerbill View Drop Down
Post Options Post Options   Quote Geezerbill Quote  Post ReplyReply Direct Link To This Post Topic: How to clean silicone sealant
    Posted: 25 Jul 2024 at 2:36pm
I have a 2022 Rpod 192 that I noticed a water leak inside the trailer where the outside water to tank line connects. Water was dripping between the water line and fitting. I had to remove the three screws Golding the fitting to the outside wall in order to pull out the fitting and hose to repair the leak. My question is what do I use to remove all of the silicone sealant that was around the hose fitting and what sealant should I use to replace the old with new. Thanks, Bill
Post Options Post Options   Quote lostagain Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2024 at 5:58am
To clean off silicone try isopropyl alcohol.  Silicone does not adhere well to polypropylene.  You may want to try a product that is made to bond to that kind of plastic, such as Loctite Plastics Bonding System or a polypropylene based hot glue.
