Winterize - Event Date: 05 Oct 2023 |
Page <12 |
Joined: 23 Feb 2012 Location: Kewadin, MI Online Status: Offline Posts: 3431 |
Calendar Event: WinterizePosted: 13 Nov 2023 at 8:33pm |
I don't level, but eyeball it so that it appears close to level. Since nothing is operating it isn't necessary. Mine is stored in an old horse barn so elements are not a factor. If yours is outside it may be an advantage to tilt is either up or down front to back to help alleviate snowloads when you get those warmer days and it can slide off.
seafans
Joined: 24 Nov 2017 Online Status: Offline Posts: 168 |
Posted: 21 Nov 2023 at 12:50pm |
I finished winterize my 192. I haven't seen in any of the posts about blowing out the water in the water-saver line from the shower. There was more water in it than one would think. When this is done it also blows out the water out of the vent line from the water storage tank. Don't stand in front the tank water fill or you will get wet. Be sure the drain plug or valve closed on the fresh water tank or this procedure won't work.
Joined: 29 Nov 2015 Location: Wake Forest, NC Online Status: Online Posts: 6484 |
Posted: 22 Nov 2023 at 9:05am |
Our current Cherokee Grey Wolf did not come equipped with the Shower-Miser. I added it. Since I could not get to the vent line (vented under the trailer, not to the fill-port vent), I had to run the return line for the Shower-Miser to the fill line for the tank. Any water thus purged goes into the fresh water tank and the drain valve needs to be open so that the water can drain from the fresh water tank. I agree that the shower-miser return line also needs to be purged, and that is likely something easily forgotten.
mark114
Joined: 10 Jan 2024 Online Status: Offline Posts: 1 |
Posted: 30 Jan 2024 at 3:25am |
Any RV owner can benefit greatly from understanding how to winterize an RV without using antifreeze. It will be possible for you to get your RV ready for the next severe weather and avoid any harm from happening. You can also return to your RV in good shape because winterizing it will help keep all of its features intact. |
Posted: 30 Jan 2024 at 8:09am |
Pretty much the way this has been done on our 177 for the past 12 years. HOWEVER, I would be leery of not adding any antifreeze to the traps. Realize there is room for water to freeze and expand however i use 16 oz. of antifreeze for the 3 traps and a tad for the toilet to keep the seal moist and from drying out over the winter months.
Posted: 30 Jan 2024 at 9:56pm |
Also, our Cherokee came with trapless drains that don't retain water. Instead, they use a one-way valve to allow water to drain but don't allow fumes back through. No RV antifreeze needed there. I only need a little in the toilet bowl to keep the seal lubricated. I expect the gallon of antifreeze I bought to last a number of years.
Page <12 |
