Towing Rpod 178 |
StephenH ![]() podders Helping podders - pHp ![]() ![]() Joined: 29 Nov 2015 Location: Wake Forest, NC Online Status: Offline Posts: 6456 |
![]() ![]() ![]() ![]() Posted: 21 Jan 2024 at 9:18pm |
Having used a 2016 Escape to tow a 2016 RPod 179, I would advise you to go for something with a higher tow rating. Make sure it is rear-wheel or all-wheel drive as when the front end is lifted from the trailer weight, front wheel drive vehicles have diminished traction and steering capability. I speak from experience that you would not be happy with it. |
EchoGale ![]() Senior Member ![]() Joined: 10 Mar 2019 Location: FL Online Status: Offline Posts: 469 |
The BMW X3 30i (2018 and newer) has a tow rating of 4400 lbs and even one as new as a 2020 would be well within the price range you indicated. I get about 30 mpg with mine (a 2020) when not towing and 15-17 when towing. I'm VERY happy with it both as a tow vehicle and my everyday car.
Julie
wunderlong88 ![]() Newbie ![]() Joined: 20 Jan 2024 Location: Texas Online Status: Offline Posts: 2 |
Thank you. I had read some of the threads here and I suspected neither of those were going to be enough.
TY
JR ![]() Senior Member ![]() Joined: 31 Aug 2018 Location: Manistee, MI Online Status: Offline Posts: 387 |
+1 lostagain Well said
Jay
179/2019 |
There are tons of threads in this forum about the needed towing capacity for your trailer. Don't be fooled by the "dry weight." To get a real idea of what you will be towing, add the dry weight to the load capacity the trailer can carry; the gross vehicle weight rating. Your trailer comes in at about 3,800 lbs. Towing at the ragged edge of your vehicle's capacity will really stress the suspension and drive train and can lead to some control issues in windy conditions. You also need to consider the combined gross weight rating for your tow vehicle. You need to be below the gcvwr which includes the tow vehicle and contents and the total weight of the trailer. There are lots of SUV's and small trucks with towing capacities that are greater about 4,500 lbs out there, but the mileage when not towing ain't so hot. Good luck finding something that will work.
Hello. I am new to the forum and am looking for ideas of a small to midsize suv that might be able to tow my 2016 Rpod 178. It's dry weight is 2600 lbs.
I wondered if the Ford Escape or Toyota Rav4 (2023 or later on either with 3500 lb tow rating) would be sufficient to pull this camper. We are in Texas and have a 20+ year old Chevy 1/2 ton we pull it with right now. We generally go to State Parks in Texas and mostly flat to small hilly trips. Nothing crazy. Could use the truck if we did otherwise. If not one of these vehicles any suggestions. Need 30+ mpg (when not pulling) and $35,000 budget roughly. Thanks!
