Refrigerator gas operation help please |
Page 123> |
Pod People
Joined: 22 Sep 2011 Location: Chapel Hill,NC Online Status: Offline Posts: 1097 |
Topic: Refrigerator gas operation help pleasePosted: 14 Dec 2023 at 1:07pm |
Our 179 has a Dometic RM8501 refrigerator with a new problem while operating on gas mode. It works fine on electric and battery power. It has worked fine on gas until now. It will ignite and continue burning. However, it "pops" and "burps", the flame turns off and immediately comes back on. This happens several times per minute and each stoppage lasts for a second or two. The flame always comes back on-sometimes with the igniter and sometimes it doesn't stay off long enough for the igniter to work, but still the flame comes back(I guess that the burner is hot enough to re-ignite the gas) It seemed to be bad propane, so I changed tanks. Same issue. I turned the tank off, purged the propane lines ans still have the same issue. I broke it down and cleaned the burner, the igniter, the flame sensor and the orifice as well as blowing out the line from the gas valve to the burner. We still have the same issues. I redid all of the cleaning process, including soaking the orifice in alcohol for 45 minutes-same issue. I have pulled/pushed/twisted all wiring coming into or out of the electrical boxes on the rear of the refrigerator and no change. It doesn't seem to be a physical/mechanical problem. Now, I'm thinking it must be either (1) the gas valve is stopping the gas flow for an instant and then returning to normal OR (2) there is an electronic issue in one of the circuit boards that is causing the issue. I have called Dometic technical services and they are NO help. They say take it to a qualified service tech(which I may ultimately have to do) I would appreciate any thoughts or suggestions. thanks Travel often and safe Vann
Pod People
Posted: 14 Dec 2023 at 1:10pm |
I should add that I tested the stove burners and the heater-all worked fine. The tank is 3/4 full and the pressure seems normal for stove burners. so, I am fairly confident it is NOT a propane problem. Vann
JR
Joined: 31 Aug 2018 Location: Manistee, MI Online Status: Offline Posts: 408 |
Posted: 14 Dec 2023 at 2:56pm |
Hi Vann,
That doesn't sound like normal operation even for a dometic. The pops and burps happens several times a minute right? The pops and burps are a few seconds long right? And these continue for the entire time the fridge is on the gas mode right? How long have you run the fridge playing that tune? Have you run the fridge lone enough to tell if it does an adequate job at cooling the fridge while harmonizing? Does the flame seem to be bright blue and is it of a good size? The only thing that comes to my mind is that there is a bimetal sensor that should be in the flame that has to check the presents of a flame or it will shut down the gas flow. There maybe an intermittent problem with that sensor. Hope this helps you.
Jay
179/2019 |
Pod People
Posted: 14 Dec 2023 at 4:02pm |
Hello Jay Thanks for the quick response- yes--the spits/pops/burps do last about 1 second and continue seemingly forever. I have left it on for 15-20 minutes and it is the same. I have not tried to actually cool the fridge since this started(except electric, which worked fine). the flame is strong-deep blue and you can actually hear it. I know the flame sensor you ask about-it glows orange and i also cleaned it with steel wool and alcohol. Do you know how to test the sensor or where to find a replacement? Thanks for your help Vann
JR
Posted: 14 Dec 2023 at 7:08pm |
Hi Vann,
Reading your fridge's symptoms and your remedies the only thing that came to mind could be a faulty flame sensor. I don't know how to verify its workability or where you can find a replacement. I found this link on youtube which seems to be relevant to your fridge's symptoms https://www.youtube.com/watch?v=biybQ7qI4Fo6/2-6/9 Hope this helps.
Jay
179/2019 |
Pod People
Posted: 14 Dec 2023 at 8:48pm |
thanks for the video. Unfortunately,the video issue is not my problem. His is an igniter that will not stop. My problem seems to either the flame sensor or something electronic that controls the gas valve. It seems like the gas is turned off for a half second, the flame burps/spits and goes out. Immediately, the flame returns(good, bright blue) sometimes spontaneously and sometimes one click of the igniter. I know the igniter works. I cannot find a parts diagram for the RM8501 to find a part number for the flame sensor. I will try again to talk to Dometic tomorrow. Thanks for your help Vann |
Posted: 14 Dec 2023 at 10:48pm |
Did you also blow out the line between the refrigerator and the gas tanks? There may be some oily crud in the line that isn't between the valve and the burner. If you do that, be sure to have a bucket under the end of the gas line when you disconnect from the regulator and blow from the refrigerator end. If you have never done this, you might be surprised at the amount of oily liquid that gets blown out of the line.
Joined: 23 Feb 2012 Location: Kewadin, MI Online Status: Offline Posts: 3436 |
Posted: 15 Dec 2023 at 9:35pm |
+1 StephenH brings up a valid possibility. At 8 years of owing our 177 we had issues that weren't as severe as yours (no popping or burping) but it would turn off and go back on. The issue was a bunch of oily crud in the line between the regulator and the metal line that is at the front of the pod. Funny thing is that both the stove and furnace still functioned normally, only the fridge was funky. So the rubber line was removed and blown out as well as from the gas valve to the front of the pod where the rubber line screws in. The regulator had to be replaced (cost then (4 years ago - $ 18).
Pod People
Posted: 15 Dec 2023 at 9:58pm |
thanks everyone for your ideas and suggestions. We are leaving Monday for a short 4 day trip, so I have put off any further work on the fridge for now. We will be staying in a US Park Service campground with power, so I will use 120v for the fridge. a potentially new development has come up. We talked to a mobile repair service and a dealer who we have used before. It sounds like it could be a control board issue. If so, we will spend several hundred diagnosing and repairing plus the parts cost. could be $5-600 or more-and it's still a 2015 model approaching 9 years old.Plus, we have had a lot of trouble with this unit over the full time that we have owned it(2017) So we started thinking about removing the microwave and putting in a new , larger(6 cu ft) refrigerator. Both Dometic and Norcold make a unit that we can make fit into the combined fridge/microwave cabinet. We never use the m/w as we normally boondock anyway. We can pull out the old fridge and adapt the cabinet and let a dealer purchase and install a new model. So......... anybody got experience doing this? or with Norcold? Again, thanks Vann
Posted: 16 Dec 2023 at 7:43am |
You are making a wise decision. Our dometic lasted 9.5 years, and were told the lifespan on these are 10 years, so unfortunately it seems like yours is near the end of life as well. It was replaced with the same model. Question do either of the units you are looking at work on propane as well as shore power? It seems like a lot of manufacturers are getting away from propane - which is not good - that is all we use - as we normally camp where no electric is available.
Page 123> |
