  New Posts New Posts RSS Feed: Fresh water drain
Fresh water drain
Mtngrannie View Drop Down
Post Options Post Options   Quote Mtngrannie Quote  Post ReplyReply Direct Link To This Post Topic: Fresh water drain
    Posted: 02 Oct 2023 at 7:43pm
New to forum.
I'm an old lady with a 2012 Frog. Getting to the fresh water drain plug is tough for me. Has anyone found an easier solution to draining the fresh water tank?
EchoGale View Drop Down
Post Options Post Options   Quote EchoGale Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2023 at 7:47pm
Hi there...it isn't located in the easiest spot, is it? Depending on how full the tank is you could run your fawcett and shower hose and then empty the gray tank....
Julie
Post Options Post Options   Quote StephenH Quote  Post ReplyReply Direct Link To This Post Posted: 04 Oct 2023 at 11:15am
You could also (probably with help) put an elbow on the drain and run a section of hose out to the side where you can reach it. I would put a valve on it instead of using another plug if you do so. That should make it easier.
Post Options Post Options   Quote lostagain Quote  Post ReplyReply Direct Link To This Post Posted: 04 Oct 2023 at 2:51pm
It would be easy to put an elbow and a length of pipe to the side of the trailer with a valve at the end, but it is something that could get knocked off by road stuff, especially if there is limited clearance under the tank.  The length of pipe would have to be well supported to protect it from damaging the tank fitting.
Post Options Post Options   Quote EchoGale Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2023 at 10:44am
That's what you get here.  :)
1) well-planned options from/for folks with, skills, contacts, or money
2) work-arounds from/for those without
lol
Julie
