  New Posts New Posts RSS Feed: slide out question
slide out question
jmlefler View Drop Down
Post Options Post Options   Quote jmlefler Quote  Post ReplyReply Direct Link To This Post Topic: slide out question
    Posted: 25 Sep 2023 at 7:02am
How did you adjust the rollers? Have the same issue with a pretty deep gouge. TIA
Post Options Post Options   Quote jato Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2023 at 8:48am
Yes, the manufacturer of the slide system is Lippert.
There is no adjustment on the rollers, the reason for the gouging is because the rollers have froze on the shaft due to lack of lubrication.  Get a penetrant (avoid products like WD-40), Schaeffers makes an excellent penetrant, Tri-Flo is another, and with the nozzle squirt both sides of the roller where it makes contact with the roller shaft and do all 3 rollers.  Get a friend to move the slide in and out while you visually look at each roller to make sure it has freed up and is now rolling as the slide moves.
zzimmer3 View Drop Down
Post Options Post Options   Quote zzimmer3 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2023 at 6:57pm
Mine adjusted with a socket and rachet. I just turned it clockwise and raised it up. The roller was adjustable on mine. It wasn't frozen up, I did lube it with triflow spray, though. I will get pictures tomorrow. With the slide out deployed, I could access the adjuster from the outside, I just pulled the rubber seal down and exposed the bolt.
Post Options Post Options   Quote jmlefler Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2023 at 11:38am
I see a bolt but can't see the roller from the outside (difficult even from the inside). Yes, a picture might be helpful. Thanks!
Post Options Post Options   Quote zzimmer3 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2023 at 6:45am
i believe its a 7/16" socket to adjust it. i turned it clockwise and watched the roller go up. i just matched the height of the other roller.
Post Options Post Options   Quote jmlefler Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2023 at 7:27am
Thanks... I found that too... I may have to lower the opposite roller assembly... awesome!
Post Options Post Options   Quote zzimmer3 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2023 at 8:04am
you are welcome. you can see how mine rubbed pretty hard on the roller bracket. it looks like crap. it goes in and out much better now, i did lube it as well.
