My 2014 172 podmods |
Page <1 234 |
abikerider
Joined: 25 Dec 2022 Location: CA Online Status: Offline Posts: 25 |
Topic: My 2014 172 podmodsPosted: 05 May 2023 at 10:05am |
Hi gpokluda, I love my LHT. It hasn't seen much use lately, but I have used it a lot in the past as a commuter and for some on/off road bikepacking trips. It's a real workhorse. With the ability to put mountain bike tires on it, it's my do-anything bike.
abikerider
Posted: 08 May 2023 at 1:55pm |
Well I started removing both bunk beds over the past weekend and building a new bed platform at a height of 18" which will change the bed width from 44" to 46" and every little inch counts. I've changed the original design and now it mimics USA house construction with 1"x2" studs at less than 16" on center. The stud wall supporting the bed will go all the way around the perimeter and I think will double the weight bearing ability of the bed without adding much weight. I'm doing lots of precision cutting with my chop saw and table saw since the two sides are not exactly symetrical. It's very time-consuming, but I think the final product will be worth it. It really changes the feel of the bed area, much less claustrophobic.
abikerider
Posted: 23 May 2023 at 3:32pm |
Here are some pics of the new bed frame being built. I used the paneling that was on the bottom of the top bunk for the front of the bed to match the other cabinets. The frame height is 18 inches. Still painting the plywood for the top so I will show that next.
EchoGale
Joined: 10 Mar 2019 Location: FL Online Status: Offline Posts: 469 |
Posted: 24 May 2023 at 10:55am |
Very Nice! Your use of the paneling is clever.
I'm not sure how you feel about the storage in the 172 but there wasn't enough for me and, for me, lifting the bed or the cushions to get under them was to hard. I removed the paneling under the bed and under the dinette seats and added storage boxes that can pull out like drawers. I used trim to finish off the rough pieces of wood that made the frame. I think the 172 is one of the most versatile floor plans ever. :)
Julie
Posted: 24 May 2023 at 2:14pm |
Very nice work. Looks like the same concept we used to raise and widen the bed. Did you leave any of he upper bunk in place. We left it in where it was next to the head on the port side wall. it made some handy storage. We also reused the plywood that matched the other wood for the side of the bed.
abikerider
Posted: 24 May 2023 at 4:21pm |
No, I did not leave any of the upper bunk. I may add a shelf later though.
Posted: 24 May 2023 at 5:01pm |
I should have taken it out and put it up higher. It became a knee knocker in the bed.
Page <1 234 |
