  New Posts New Posts RSS Feed: LifePo4
LifePo4
 Post Reply Post Reply Page  <12345>
EchoGale View Drop Down
Post Options Post Options   Quote EchoGale Quote  Post ReplyReply Direct Link To This Post Topic: LifePo4
    Posted: 06 May 2023 at 7:54pm
One more update: I've been traveling for ten days without access to electrical hookup. I couldn't be happier with my new batter set up. I went with the Renogy 100AH despite the price.
One at the higher price was fine (I needed batteries so I was going to spend 2-300 anyway so 475 wasn't much more)-- but I was afraid I'd decide to add a second and that would have been too much.
As it turns out the new camper's rooftop solar panels easily top off the daily usage (which is only about 15%)--even on this stretch of rainy days we've had on the east coast. I definitely don't need a second battery.
Such an upgrade from my old system: 2 golf cart batteries (heavy!) where I was always pulling to boxes apart to chef the charge level and hauling around my heavy portable solar panel to keep them charged up...not to mention maintenance.
It's a sweet setup. Thanks again for the advice while I was figuring it out.  :)
Julie
Post Options Post Options   Quote StephenH Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2023 at 7:46pm
Before assuming that your Tacoma has a standard and not a smart alternator, check with a local Toyota dealer. They should be able to tell you. I don't know.
Hood View Drop Down
Post Options Post Options   Quote Hood Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2023 at 7:05pm
Thanks Stephen!
I am driving a 2005 tacoma so would guess I don't have a smart alternator.  I had read the newer WFCO s adjust to the LiFePO4 but had seen a post on a different site were someone had a problem, so wanted to reach out before putting one in.   When it comes to electricity i'm almost as green as r poding which consist of two months Smile.
David
Post Options Post Options   Quote StephenH Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2023 at 6:08pm
Originally posted by LB Boozer
When you refer to “smart” alternators what exactly are you referring to and how would one know if they have a “smart “ alternator?  Our TV is a 2007 1/2 ton truck so don’t know if they were using what you refer to as smart alternators yet.  If one did not have a smart alternator and is not really concerned with charging from tow vehicle (plenty of solar and battery capacity), could one just replace the La batt with Lifepo as long as the converter and solar charge controllers were compatible?
Your vehicle specifications should let you know. I think any newer vehicle would have a "smart" alternator. The 2010 Frontier did and the 2018 F-150 does. The older alternators put out a constant voltage. The "smart" ones adjust it so that it does not place the same load on the engine when the starting battery is charged. This will help explain the difference:
LB Boozer View Drop Down
Post Options Post Options   Quote LB Boozer Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2023 at 5:49pm
Post Options Post Options   Quote StephenH Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2023 at 3:17pm
Hello David,
I looked up the WF 8735-AD. Here is what it says:
"WFCO’s proven WF-8735-AD Power Center offers an industry-first, Auto-Detect technology. This new microprocessor-driven technology will recognize lithium-ion and lead-acid battery chemistries and automatically adjust the charging profile to match the battery type."
So, it is a qualified yes. The converter will not have a problem. Solar would not be an issue. The only issue is in charging while driving. "Smart" alternators won't work as they will think the tow vehicle's battery is charged because of the higher voltage of the LiFePO4 battery and cut the charging. That will mean your house battery will be supplying power so you arrive with your battery lower than when you started. You do need to use a DC to DC charger or equivalent to both isolate the house battery from your starting battery and to have the correct charging profile for the LiFePO4 battery if you install one.
Hood View Drop Down
Post Options Post Options   Quote Hood Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2023 at 1:56pm
I have been following these posts, very helpful.   Been looking at LiFeP04 batteries.  thought this might be better choice than adding additional solar to the 110 panel I have.  I have a new r pod with WFCO WF 8735-AD and wonder if I can just replace my wet battery without additional conversions to my electrical system?
Post Options Post Options   Quote StephenH Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2023 at 6:04pm
Congratulations Julie on getting your LiFePO4 battery and getting it installed.
Post Options Post Options   Quote EchoGale Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2023 at 11:00am
An update on my battery project: I went with the Renogy 100AH Lifepo4 battery. It was more expensive that the brands on amazon but I've had good experience with the company and given the limits of my expertise, if I have a problem I wanted to minimize the number of things to be concerned about.
The install was simple and everything went as I hoped and it's charging properly with my solar panels.
It's slightly bigger than the group 24 battery I had, so I needed to use a bigger box that doesn't fit as well.  I'm not thrilled with the positioning of it but I'll likely move the battery inside at some point anyway.
Thanks for all the help everyone.
Julie
Post Options Post Options   Quote StephenH Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2023 at 1:44pm
I wasn't worried about my LiFePO4 battery although one of the videos I looked at indicated that they can swell up and put off fumes if (way) overcharged or if physically punctured. They don't burst into flames unless heated with a blowtorch. I don't think anyone would be deliberately doing those things, so they are quite safe.
