  New Posts New Posts RSS Feed: Kitchen sink replacment
bwarren View Drop Down
Post Options Post Options   Quote bwarren Quote  Post ReplyReply Direct Link To This Post Topic: Kitchen sink replacment
    Posted: 04 May 2023 at 4:01pm
We have a RPOD 177 from 2013 and need a kitchen sink replacement and am having a hard time finding a company or website to purchase one.  Any suggestions? THanks Bruce
Post Options Post Options   Quote StephenH Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2023 at 8:09pm
How about this one?
There are other options available also.
Post Options Post Options   Quote marwayne Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2023 at 11:20pm
I found this one at Home Depot
Post Options Post Options   Quote David and Danette Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2023 at 5:07am
   Go on amazon.com and do a search for "small stainless steel sinks" there are many. That's where we bought our sink for our camper you just need to know the size that you want and the size that will fit the space you have. Our camper came with a small double bowl plastic sink so I changed it for a larger double bowl stainless steel sink. I needed to use a jig saw to make the opening a little larger and the new sink is much more useful.
2023 Aliner Scout Lite
Pod People View Drop Down
Post Options Post Options   Quote Pod People Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2023 at 8:52am
We replaced our sink with an Elkay single bowl bar sink. There are several sizes available from the big box stores.
You will probably have to enlarge the opening slightly. Use clear silicone caulk to seal around the perimeter.
Travel often and safe
Vann
Vann & Laura 2015 RPod 179
abikerider View Drop Down
Post Options Post Options   Quote abikerider Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2023 at 12:58pm
I replaced our cheap white plastic sink in our 172 with an Elkay 15"x 17-1/2"x 5-1/2" Single Bowl Drop-in Sink I bought off ebay. It would have fit better if I had gotten a 6-1/2" deep model. It was the largest sink I found that would fit in the space. It also will fit normal size plates inside of it without having to tilt them. Of course you will have to enlarge the opening. I replaced my countertop at the same time with some inexpensive 1" thick butcherblock I found at Home Depot.
Post Options Post Options   Quote bwarren Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2023 at 10:14pm
Thanks for the info...I found a stainless one and cut the opening a little bigger and dropped it in...works great!  Drain pipes were a pain to re-align however we are leak free
Post Options Post Options   Quote abikerider Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2023 at 10:54pm
Yes, I also had a little trouble aligning the drain pipes. I did a lot of measuring to get the drain to be a little past the top drawer. There's always something in the way when doing any mods.
