Upgrade converter to inverter/charger |
Page 12> |
FreeRangePod ![]() Newbie ![]() Joined: 02 Jun 2016 Online Status: Offline Posts: 10 |
![]() ![]() ![]() ![]() Posted: 18 Apr 2023 at 10:04am |
![]() I am almost finished with my off grid system. I have a question. Is the Orange Romex attached to the WFCO Electrical panel the connection to the shore power plug? I am planning to disconnect it and plug into a watchdog surge protector. The output of that surge protector is a new Ancor 10/3 AWG marine wire connected to the input (AC in) of the inverter/ charger. |
FreeRangePod
2016 RPod 178 2020 Jeep Grand Cherokee |
hank*pod ![]() Groupie ![]() ![]() Joined: 06 Oct 2022 Location: PA Online Status: Offline Posts: 63 |
Hi HankPod,
The 1460 watts is only the peak requirement at start up. Wattage is similar to yours. My new system will allow me to camp off grid for 3 or 4 days. So National parks, BLM and Harvest Hosts will be free or close to it. I have saved enough by not going to hotels in the last 7 years to cover the cost of the RPod, extra gas and campsites. š Love nature so much more than another expensive, boring hotel Room. |
FreeRangePod
Your power problem will be easier to solve if you adjust your power requirements. If necessary I can plug my Mr Coffee into my Jackery for long enough to brew a pot and not hit its 800 Wh capacity too hard.
gpokluda ![]() Senior Member ![]() ![]() Joined: 11 Nov 2018 Location: NM Online Status: Offline Posts: 417 |
I tried to do as much wire routing as I could underneath the trailer, encasing the wires in wire loom. When it was time to route into the trailer, I used the smallest spade bit that would accommodate the wires and then sealed with spray foam from top and bottom.
Gpokluda
I am well into my installation of my off grid system. DC box under the dinette with 2 100 Ah lithium batteries in parallel, from positive of battery bank to 300 amp fuse to battery shutoff to positive bus bar. From negative of battery bank to Vitron smart shunt to negative bus bar. Smart shunt connected to app and setup looks correct.
Now I Need to take battery connects off tongue and connect to bus bars. Any suggestions where best to drill hole and how best to seal off? |
FreeRangePod
Colt ![]() Senior Member ![]() ![]() Joined: 16 Nov 2019 Online Status: Offline Posts: 383 |
I'll suggest a better coffee maker (Bodum) and a teapot. ![]() You might investigate a Bodum Vacuum siphon, but use a Yama filter. These are messier to clean, though. You can use it on your gas burner. Superior coffee. ![]() I use the pour over in my R-Pod for speed and convenience.
John
'16 R-Pod 180 |
Hi Gpoklida,
Thank for your reply. I am leaning towards putting the whole thing in a storage compartment, using an inverter/charger and lithium batteries. My trolling boat batteries on my bass boat were 2010 and 2014%#@, so I moved my two RPod batteries ( 2018) to the boat. Took it out yesterday, worked great! Now to choose the inverter/charger and Lithium batteries to install. |
FreeRangePod
Hi FRP, I wired the inverter as close as possible to my batteries, which meant locating it in the front storage area. My charger/converter, which is located on the other end of the trailer on a 179, was working fine so I left it in place. Apologies, I missed the part where your charger converter wasn't working in your situation. Best of luck
Gpokluda
StephenH ![]() podders Helping podders - pHp ![]() ![]() Joined: 29 Nov 2015 Location: Wake Forest, NC Online Status: Offline Posts: 6463 |
Remember that the converter is doing two things: Supplying 12V power to the RPod and charging the battery. An inverter/charger is doing much more. In addition to charging the battery, it is also monitoring the AC power input and when that is disconnected, transferring to battery/inverter power to keep your AC items running, much like an uninterruptible power supply for your computer. It much be much bigger to do these things. You would need to find a different mounting point for an inverter/charger. In my case, I think there would be adequate space behind the power panel if I were to do that. However, I haven't found a need to have an inverter running. Given, I do carry a generator for when we are traveling and don't have shore power available and I want to run the AC or the microwave. Neither would be suitable to run on an inverter anyway, not in the RPod at least. A motor home with lots of room to carry a large battery bank, perhaps, but not the RPod.
Page 12> |
