LifePo4 |
Page <1234 5> |
Joined: 15 May 2017 Location: N. California Online Status: Offline Posts: 2792 |
Topic: LifePo4Posted: 20 Mar 2023 at 11:11am |
It would be nice if vehicle batteries started coming with LFP batteries.
Secondarily, it would be nice if vehicles cam with 48V battery systems. I know Tesla is switching to 48V for all internal systems (separate from the motors). This may become a trend because it allows you to eliminate a lot of copper (which weighs a lot).
Posted: 20 Mar 2023 at 1:18pm |
I think one reason is that it is hard to control the external environment. LiFePO4 batteries do not like to charge below 32F (0C). For a battery to be used in a vehicle, there would need to be a way to warm the battery in freezing environments. Likewise, they don't like getting too hot. I've read enough stories of battery powered vehicles bursting into flame. For the time being, lead-acid batteries are still safer for use as starting batteries. That may change as newer battery technologies become available.
EchoGale
Joined: 10 Mar 2019 Location: FL Online Status: Offline Posts: 469 |
Posted: 20 Mar 2023 at 6:14pm |
Thanks for the new round of comments. The BMS in one of these lower prices off-brand batteries comes with the ability to warm itself and that is of great interest to me because I do camp in temps between the low 20s and freezing. How worried do I need to be about my whole camper bursting into flames???? (STEPHEN!!!!)
Julie
Posted: 20 Mar 2023 at 8:36pm |
I don't think you have to worry. LiFePO4 batteries are much better than Lithium Ion batteries used in vehicles. I believe the one I bought does have the ability to self-warm. Here are the operating temperatures for the one I am using:
Charge 0C-50C (32F-122F) Discharge -20C-60C (04F-140F) Storage -10C-50C (14F-122F) Unless you are camping in Death Valley in the summer, I don't think you will have a problem with heat. As for cold weather use, you can mount it inside since it doesn't put off fumes. Given that these cost a lot, having it inside is also better protection against theft. Mine is inside of a locked metal Harbor Freight tongue box that is U-bolted to the A frame. I do have some foam padding for insulation. I have had no problem with using it when it was inside under the bed in our RP-179. This site has a good comparison and may help ease your mind. |
Posted: 21 Mar 2023 at 10:28am |
LFP batteries do not have the fire risk of the various "Lithium Ion" batteries. From all the things I've read, they appear to be as safe as lead acid.
EchoGale
Posted: 21 Mar 2023 at 10:32am |
That's a helpful article :)
I wasn't that worried and was mostly teasing you.
Julie
Posted: 21 Mar 2023 at 1:44pm |
I wasn't worried about my LiFePO4 battery although one of the videos I looked at indicated that they can swell up and put off fumes if (way) overcharged or if physically punctured. They don't burst into flames unless heated with a blowtorch. I don't think anyone would be deliberately doing those things, so they are quite safe.
EchoGale
Posted: 08 Apr 2023 at 11:00am |
An update on my battery project: I went with the Renogy 100AH Lifepo4 battery. It was more expensive that the brands on amazon but I've had good experience with the company and given the limits of my expertise, if I have a problem I wanted to minimize the number of things to be concerned about.
The install was simple and everything went as I hoped and it's charging properly with my solar panels. It's slightly bigger than the group 24 battery I had, so I needed to use a bigger box that doesn't fit as well. I'm not thrilled with the positioning of it but I'll likely move the battery inside at some point anyway. Thanks for all the help everyone. |
Julie
Posted: 08 Apr 2023 at 6:04pm |
Congratulations Julie on getting your LiFePO4 battery and getting it installed.
Hood
Joined: 08 Apr 2023 Online Status: Offline Posts: 7 |
Posted: 23 Apr 2023 at 1:56pm |
I have been following these posts, very helpful. Been looking at LiFeP04 batteries. thought this might be better choice than adding additional solar to the 110 panel I have. I have a new r pod with WFCO WF 8735-AD and wonder if I can just replace my wet battery without additional conversions to my electrical system?
Page <1234 5> |
