  New Posts New Posts RSS Feed: Battery Disconnect
Battery Disconnect
Colt View Drop Down
Post Options Post Options   Quote Colt Quote  Post ReplyReply Direct Link To This Post Topic: Battery Disconnect
    Posted: 09 Feb 2023 at 7:57pm
My battery disconnect switch has become so stiff I cannot move it by hand. I want to replace it with a quality switch. Any suggestions?
My nearest RV dealer was out of stock.
John
'16 R-Pod 180
Post Options Post Options   Quote StephenH Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2023 at 9:20pm
You could check Amazon to see if you can find one. Look for a marine one. The problem is that they are outside and exposed to all kinds of conditions. I purchased one like this:
I had it outside for a while, but when I installed the Lithium Iron Phosphate battery, I moved it inside to be close to the battery.
Post Options Post Options   Quote offgrid Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2023 at 4:16am
I'd suggest getting an old school battery top post knife switch. Like anything else exposed outside it can get corrosion but since the switch part is open its easy to inspect and maintain. About $13 on Amazon.
gpokluda View Drop Down
Post Options Post Options   Quote gpokluda Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2023 at 2:22pm
I used the same one as StephenH. Simple and serviceable.
Gpokluda
2017 Rpod 179(sold 2023)
2022 Escape 5.0TA
2022 Ford F150 4X4 3.5EB
Honda SCL500
Colt View Drop Down
Post Options Post Options   Quote Colt Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2023 at 8:43pm
I bought this one.  It looks sealed.  So far, so good.
https://www.amazon.com/Blue-Sea-Systems-Battery-Switch/dp/B00445KFZ2/ref=sr_1_3?crid=2WVBGXE2012XW&keywords=marine+battery+disconnect&qid=1677465748&sprefix=marine+battery+disconnect%2Caps%2C129&sr=8-3
John
'16 R-Pod 180
