12 to 6 v battery switchout |
Page <1234 5> |
EchoGale
Joined: 10 Mar 2019 Location: FL Online Status: Offline Posts: 469 |
Topic: 12 to 6 v battery switchoutPosted: 07 Dec 2022 at 7:35am |
Again, thanks so much for al the help. I'll be able to pursue the suggestions later today (I hope). Some follow-up points:
1) They sat for just under two months 2) After a couple of years of reading about the 6 v batteries I never saw that they can discharger faster, I wish I had as I might not have done it because my camper is parked where I cannot plug it in. 3) I don't have an "off season" so I guess I'll try to get a solar tender. 3) I have this same kind of disconnect switch and I keep it set on "off" or "both" One day I'm going to make it to a rally in hopes of having someone teach me to use my multimeter. I only know how to test the charge on my batteries. This is way beyond my capabilities (honestly, with I can't even read this lol): " Put your multimeter on the ohms scale and connect it across the switch terminals. You should get an open circuit (or very high ohms) reading with the switch open. Then with the switch still disconnected from the battery close the switch and measure the ohms again. You should get a reading in the 0 to 1 or so ohms range." Just for fun I put the terms I don't understand in italics. :) You all have been awesome as always; I'll report back. |
Julie
hogone
Joined: 09 Apr 2013 Location: High Ridge, MO Online Status: Offline Posts: 1077 |
Posted: 07 Dec 2022 at 8:09am |
Im with you EchoGale!!! Multimeters are way beyond me (BTW, I had to spend 2 years in kindergarten!!). jon
Jon & Pam
2025 GD 17MKE 2013 RP177(sold Nov 25) 2023 F150 CHEESEHEAD |
Posted: 07 Dec 2022 at 8:33am |
Okay. I think I can help with this.
Ohms scale: On your meter, you should have a dial with various things like DCV (Direct Current Volts), ACV (Alternating Current Volts - your usual house plugs are 120V AC), DCA (DC Amperes), ACA (AC Amperes), Ohms (May be on the dial as a Greek letter Ω (Omega) which is the symbol for Ohms) and possibly battery test and transistor test functions. Ohms may be divided into 2000k, 200k, 20k, 2000, and 200 Ohms. Your meter may be different. Ohms is the symbol used to measure resistance. Take the multimeter and put it on one of the Ohms settings. You should have a reading of 1, which indicates that there is no current flowing. Touch the tips together. The digital display should change to 0.00 for digital or the needle should move to 0 on the OHMS scale on a meter with a dial and needle. That is what indicates that there is a closed circuit and that current is flowing. If the reading is anything but zero, then that is the resistance of the circuit. your battery switch should have three connections. One goes to one battery, one to the second battery, and the third to the load (the trailer wiring). With the batteries disconnected, turn the switch to Off. Put one probe on the terminal that leads to the load. Touch the other two terminals, one at a time with the other probe. The reading should stay at 1 (or very high on an analog meter). Turn the switch to battery 1. Again, one probe goes to the load, the other to the terminal for battery 1. The meter should move to 0 or very close to it. Touch 2 and it should stay at 1. Move the switch to battery 2. Again, one probe goes to the load and the other probe goes to the battery 2 terminal. The reading should be 0 or close to it. Then touch the Battery 1 terminal. The battery 1 terminal should remain at 1. Last, turn the switch to Off. Touch the Battery 1 and Battery 2 connections. The reading should remain at 1. If all these give you the results I mentioned, then your switch is functioning normally. I hope this helps clarify for you what was meant.
EchoGale
Posted: 07 Dec 2022 at 11:49am |
Stephen this is very kind of you and I will try but, I know its hard for you to fathom because it seems so obvious to you, but this is still over my head. Like I do not know what a terminal is. I'm not asking you to explain, just trying to communicate why I don't completely understand. We live on different planets. :)
Julie
Joined: 15 May 2017 Location: N. California Online Status: Offline Posts: 2783 |
Posted: 07 Dec 2022 at 3:24pm |
+1 Same. I do have a reminder every 3 months to check the water. When we stored our Rpod in a storage facility for a while, we pulled the batteries and kept them on a bench. That was a bit of a pain, as I would put them on a charger periodically. I guess you could also put them on a trickle charger, which is not an expensive proposition.
Posted: 07 Dec 2022 at 3:51pm |
A terminal is a place where a wire attaches. The wire terminates there. Thus, terminal. If a wire does not attach to anything, nothing happens. I would like to help you understand. Thanks for letting me know that I left that part out of my previous reply. We all start from somewhere. There was a time when I did not know what a terminal was either or many other things. |
hogone
Posted: 07 Dec 2022 at 4:54pm |
Oh my, all this talk on batterys got me thinkin. I bought two 6 volts about 3 years ago, and for some strange reason I always thought they were sealed. So I decided tonight I would be curious and check. NOPE!!!! Used over a gallon of distilled water topping them off. Dam, my parents should of kept me in 3 years of kindergarten. Obviously 2 wasnt enough!! jon
Jon & Pam
Posted: 07 Dec 2022 at 5:08pm |
Good thing you checked. A gallon of distilled water is a lot of water. They must have been quite low.
hogone
Posted: 07 Dec 2022 at 5:15pm |
Ya, I would say over a gallon is quite a bit!! I'm sure I have degraded them. I do have another question. I am only assumming batteries are intially filled with battery acid. I recall when I was younger when I would by motorcycle batterys, the acid came in a separate container and you would fill the battery yourself. I have always known to top off with distilled water, but why water instead of acid?? jon
Jon & Pam
Posted: 07 Dec 2022 at 7:15pm |
Why? Because as the water is turned to oxygen and hydrogen as the battery charges or evaporates from heat, the sulfuric acid becomes more and more concentrated. Adding distilled water restores it to the proper dilution for proper operation.
Page <1234 5> |
