Winterizing a 2022 RPOD 192 |
Page <123 |
hogone
Joined: 09 Apr 2013 Location: High Ridge, MO Online Status: Offline Posts: 1077 |
Topic: Winterizing a 2022 RPOD 192Posted: 08 Nov 2022 at 6:09pm |
many thanks jato! Putting in the new pump tomorrow. Old one is removed. jon
Jon & Pam
2025 GD 17MKE 2013 RP177(sold Nov 25) 2023 F150 CHEESEHEAD |
gpokluda
Joined: 11 Nov 2018 Location: East Idaho Online Status: Offline Posts: 509 |
Posted: 08 Nov 2022 at 8:01pm |
Same here, hogone, there is some great winter camping to be had, that's why I never winterize with antifreeze and choose to purge the system. Granted here in central New Mexico, it rarely dips below the teens and when it does, it is usually followed by a sunny 40degree day. Not nearly the cold you experience in the midwest.
Stay warm! |
Gpokluda
2017 Rpod 179(sold 2023) 2022 Escape 5.0TA 2022 Ford F150 4X4 3.5EB Honda SCL500 |
hogone
Posted: 09 Nov 2022 at 4:38pm |
OK, 2 things you guys. Just put in new pump, all good there and no leaks!! I fired it up, ran water through all the faucets, turned off all faucets; and about every 5-10 seconds it(pump) pops on for a sec (what the heck). I checked everything and no leaks anywhere. Any clues? What the heck. Also one more question about the using air to blow out the lines just to make sure. When I blow air, the little winterizing hose should be open like I'm pumping antifreeze, or closed? The hot water heater is bypassed. Thoughts much appreciated. jon
Jon & Pam
Posted: 09 Nov 2022 at 5:08pm |
Since you will not be pumping antifreeze through it, the valve should be closed.
hogone
Posted: 09 Nov 2022 at 8:52pm |
Thanks Stephen. Any ideas why the new pump kicks on when no faucets are open. I cant find any leaks. jpp
Jon & Pam
Posted: 09 Nov 2022 at 10:10pm |
Could be the check valve in it is allowing a small amount of leakage back through the pump. If you have one of the new-fangled ShowerMiser valves, make sure that is not allowing water through. You might not notice that leaking unless enough were leaking to allow it to change colors. Other than making sure the low point drain caps are on tight, I can't think of a cause. I notice it with mine too, but it is not as often, but my pump is older.
Joined: 23 Feb 2012 Location: Kewadin, MI Online Status: Offline Posts: 3443 |
Posted: 10 Nov 2022 at 5:36am |
My pump started to momentarily turn on and off a few years ago; at that time the pump was 9 years old and the only thing noted was the pressure relief valve on the HW tank had a slight drip to it. After opening and closing the pressure relief valve several times the dripping stopped, but the pump turning on and off didn't. The pump is now 12 years old, and yes, it does kick on and off for maybe 1/2 to 1 second once or twice a day. No leaks found so it must be an internal issue with the pump. Maybe it will get replaced as it is quite noisy anyway. Any suggestions as to a quieter pump, if there are, it will definitely be replaced.
hogone
Posted: 10 Nov 2022 at 4:56pm |
First, many thanks for everyones input on the pump and winterizing with air. I ran some water through the pump today (before blowing out the lines), and it was not cycling!!!! Maybe it just needed to get warmed up. I cant beleive I have gone all these years winterizing with anti freeze, blowing out lines was a breeze! A little juice in the traps is it. Final thing. Any reason to keep the old pump, or just more clutter in my garage!!? GO PACK!!!! jon
Jon & Pam
Posted: 10 Nov 2022 at 7:50pm |
I would pitch the pump BUT KEEP the glass bowl and screen in case yours were to ever break.
Posted: 10 Nov 2022 at 8:30pm |
On mine, it was a plastic bowl with stainless steel screen. I changed mine when the one I had got cloudy, probably from the RV antifreeze I had pumped through it. I switched to air and the replacement bowl has remained clear.
Page <123 |
