fuse or circuit ? |
Mike&Sally
Joined: 09 Aug 2015 Location: Kentucky Online Status: Offline Posts: 11 |
Topic: fuse or circuit ?Posted: 25 Jul 2022 at 7:48pm |
2016 Rpod179, no power to the carbon monoxide/propane gas alarm - is it a circuit or fuse ? Which one ? There's no LP label. Everything else is working.
TheBum
Posted: 25 Jul 2022 at 8:01pm |
Fuse. If it's blown, you should see a red light next to the blown fuse. If not, the detector itself may have failed. If it's the original detector that came with the Pod, it needs to be replaced anyway because they only have a 5-year service life.
Alan
Joined: 14 Jan 2013 Location: Near Nashville Online Status: Offline Posts: 1456 |
Posted: 25 Jul 2022 at 9:16pm |
I could easily be wrong, but I don't think CO/Propane detectors are fused, or on a breaker. They are meant to be always on. TheBum is exactly right on their lifetime though. Time for a new one regardless. Check the power at the detector with a meter or even just a little 12v voltage light. I'll bet there's power there. TT
FJ Cruiser |
Posted: 25 Jul 2022 at 9:42pm |
If the LP/CO detector were out of date, it would be flashing lights and beeping. It is quite annoying. I had to replace mine. Some people have just taken it off and cut the wire and then put it back. To me, it does sound like there might be a wiring issue. However, it could be that the detector is broken in addition to being out of date. If yours is like my old one, it was surface mount. I recommend replacing it with a flush mount model. It costs a bit more, but not kicking it almost every time I walk past made the cost worthwhile.
Posted: 25 Jul 2022 at 10:01pm |
+1 on the flush mount. Do out-of-date detectors beep forever? I guess they could as long as the battery connected.... but do they beep when they're out of date or when the power dies? TT
FJ Cruiser |
Posted: 25 Jul 2022 at 10:11pm |
They need power to beep. I don't know how long the continue to flash and beep when they are out of date. It was too annoying and we had trips planned to try it. I could have saved it and connected it to a battery to see how long, but I did not think of it. Besides, it would not have gone over well with the wife.
Posted: 26 Jul 2022 at 5:45am |
If the Cwire to the CO detector doesn't have a fuse it should. Fuses don't just blow for no reason. Fuses are there so that faults don't dump the battery current, melt down the wiring and catch your trailer on fire. Every wire coming off the battery needs to be fused, at the end closest to the battery, just like everything in your house is on a circuit breaker, whether is a critical load or not.
JR
Joined: 31 Aug 2018 Location: Manistee, MI Online Status: Offline Posts: 408 |
Posted: 26 Jul 2022 at 7:54am |
I have a 2019 179 and my CO detector lost it's life this spring on a trip we were on to NM for 6 weeks and it gave us a audible notification so we had to replace it. The detector is hard wired into the trailer's 12v electrical system. Meaning that the detector had to be unscrewed from the wall and the wiring exposed and disconnected. Then the new one installed. On my trailer the circuit that the CO detector is wired into is circuit #3 which also has the wiring for water heater control circuit, the LED level indictors for the water tanks, and the water pump. Note that circuit is always live if the trailer's battery(s) are connected with power. If the fuse is disconnected or is blown the circuit is not powered.
Inside my trailer's fuse/breaker box is a wiring schematic for how my trailer is wired. Hope this helps.
Jay
179/2019 |
Mike&Sally
Posted: 26 Jul 2022 at 4:08pm |
Thx for the responses ! Removed current alarm, plugged into shore power, checked leads for voltage, none there & no red lights at the fuses. No circuit diagram in the box. Going to go with a AC plug in detector for now.
Next ? - is there wood subflooring under the linoleum ? I had a significant water leak that has been fixed, but the linoleum has buckled & split in one small area - thinking the wood has swelled. |
Posted: 26 Jul 2022 at 4:30pm |
Yes, the floor has a thin layer of plywood over a foam core. Note that the trailer walls rest on top of this plywood/foam sandwich so if the leak was near the outer walls you are pretty likely to get sagging.
Lots of owners have reported that problem (with or without water damage), and FR now makes outriggers you can install to help with that. You can use the search function to find out more. |
